Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Won't turn on
Today when I went to use my TV for the first time after work the red power light stays solidly on and will not change to green....either through the remote or manually. The TV was given to me, I believe it is 3 years old. It had been working fine to this point. Thanks in advance for your assistance.
Mike Overdorff
  • bluedorff Nov 15, 2007
    Sounds possible....so how do I go about getting to the power button?
  • bluedorff Nov 16, 2007
    I am actually a certified electronic tech...been doing it for 25 years. Just need to get a service manual to show me how to get to the switch. Any suggestions?
    Novelist:
    Champion:
  • 244 Answers
Possible there is a problem with your power button try to check it if it is still functional. Read light means standby power meaning your TV still working. If you cannot do it by yourself fixing it try to bring your TV at your nearest TV shop to check the power button.
Hoping for your kind approval to make my rate Solved for this problem.
Best regards,
Philip
Posted on Nov 15, 2007
  • Cheater Cheater Nov 16, 2007
    I would not advice you to open your TV set by your own hands but I am probably prepared to advice you to bring on shop to check the power button.
    I hope this would be a helpful to you. Please rate me solved!
    Best regards,
    Philip
  • Cheater Cheater Nov 17, 2007
    Sorry for that, but I think you have enough knowledge to fix it. I don't have any manual but I am sure all the parts and mechanism are just the same with the natural TV set.
    Just try it and I am sure you got it, atleast don't disturb other parts which is not neccessary to involve in fixing the unit.
    Good Luck.
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Mar 14, 2008 | Panasonic PT-60LC13 Television
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
