Check the fuel lines and connections again turn key into on position and should hear pump hum for a couple of seconds and stop if continues then fuel line isnt getting up to pressure (fuel line leak or fuel pump going bad } new doesnt mean cant be defective --if it does than may have to check fuel rail and throttle body(may need to be cleaned )also may need tune up plugs air filter etc.
SOURCE: Savana 2000 van geting hard to start.
I just solved this very same issue with mine... You can chase every rainbow with this one. It turned out to be a bad connection at the starter motor... sounds silly but it worked. Clean up the connections (or replace the starter like I did) Fires right up. I thought it was a sensonsor or something because it would turn over no problem but because of the connection, it just wasn't getting the right juice to fire... try it first. :)
SOURCE: FUEL PRESSURE DROPS WHEN PUMP STOPS.HARD TO START
The fuel pressure check valve in the electric fuel pump has failed, you will have to replace the fuel pump, it is in the gas tank, also replace the filter at the same time or the warranty on the new pump will be voided.
SOURCE: 2004 dodge neon hard time starting
Well it could be the pump itself going bad or a short in the wiring, possible clogged fuel filter. There is a valve what looks like a tier valve cap on the fuel rail if you can get you hands on a pressure gauge and hook it up, you should see the pressure increase and decrease, if it does not start looking elsewhere.
SOURCE: My 1998 ford mustang v6 3.8l .. is hard to start
So what you saying is it's hard to start cold right? Something in computer system not allowing excess fuel to injectors when cold. Probably sensor Get auto electrician to sort it out otherwise you end up replacing things that there is nothing wrong with They got the right gear
