Question about HP Pavilion dv9000z Notebook
Hp pavillion wont boot, i just get a black screen
I got blue screen, then upon restart the hp pavillion wont boot, i just get a black screen
the hard drive spins, no BIOS
    Scholar:
  • 95 Answers
Hello
I have read your problem and I think its a sure case of gone RAM.
Replace the RAM with a new one and your system will work fine.
Thank You
Posted on Aug 05, 2009
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
HP pavillion a6300f pc when powered on, the fans come on and can feel the hard drive spinning, however there is no video output; I took the pavillion to another pc monitor and same result, no video output....
If it shows the bios on your screen.... Try to go the bios setting and make check the "default operation" and save upon exit.
Check the Motherboard, if there are swollen/bulging capacitor on the board, replace it.
If there are no bios whatsoever, sad to say, problem will be the board already......usually the bios chip that breaks down.
Try to use another power supply, sometimes the power supply is the culprit of the boards problem.
Hope that helps you out!
Aug 09, 2011 | HP GX613AA Pavilion A6300F Desktop PC
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
I have bought new boot disc or restore disc but it runs one cd then blue screen says discs wont work.it tells me to alt ctrl and delete then shows message that ntldr is missing.I know my compaq hp stores...
for setup the bios usually by pressing delete at first screen appear
or for some type motherboard is pressing F2 at first screen appear
after you at setup bios go to boot menu
the go to select boot menu and chose boot from cd for the first boot
then press f10 to save the bios setting and computer will restart
after restart isert your boot disc and if it ask to press any key to boot from cd press any key
then follow the instruction for install the operating system
Mar 04, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Drive connected to HP Desktop running Vista Pro after one week and several re-starts PC would not boot on start-up showed scary blue screen with with drive connected without black screen then blue....
> after one week
Western Digital warranties the disk-drive to work for at least one year.
If it does not, then exercise the warranty to get a replacement, at minimal cost to you.
Try connecting it to a different PC, to see if your PC's "blue-screens" happen without it being attached.
Nov 18, 2010 | Western Digital My Book Elite...
Black screen with info that pops up immediately upon booting up
Hi:
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
Bios wont boot
Your BIOS is more than likely locked by an admin password or the options are locked upon startup. The best way to go around that is once you see the HP screen popup after restart, keep hitting F12 and the boot menu will pop up gving you access to the boot menu and then to the BIOS. If you have a password setup on the BIOS you will need it for any BIOS changes you make to take effect.
Nov 13, 2009 | Computers & Internet
Wont boot on it's on,and then gives blue screen and restarts over
this is a system32 driver issue with windows i believe. i had this same problem when i plugged in a PCI Sata Adapter it screwed a driver all up and windows was stuck rebooting over and over. the only way i could think to fix it was to format the HDD and reinstall windows from scratch
Oct 17, 2009 | HP Pavilion ze2000 Notebook
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
Wont come outof hibernation goes to a black screen even upon rest
RESTART IN SAFE MODE.
OR
REBOOT SYSTEM, BEFORE IT BOOTS PRESS
F6 UNTIL YOU HEAR THE BEEPING NOISE, THAN STOP AND SELECT SAFE MODE
THAN CONTROL PANEL AND SELECT POWER OPTIONS
POWER BUTTON OPTIONS
Mar 14, 2009 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
569 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
