Question about Amana Quiet Zone 12M12TA Air Conditioner
Problems with Amana Quiet Zone 12M12TA, kicks off after short runtime, but other times runs for an hour cooling OK. Hear a clicking when it shuts down? Could not find a fuse ot relay?
    Guru:
  • 588 Answers
Does it run longer when it's cooler outside like at night? If it is, it could be shutting down on high pressure or temperature caused by dirty condenser or you could have an overload in the compressor wire box that is weak or has a loose connection. Check the condensor coil to see if its dirty and see if it has an overload on the compressor.
Posted on Jul 28, 2009
Fan continues to run in the off position?
The contacts in the switch are welded shut (if this is a portable unit). On a central system, the fan relay contacts are welded shut.
Oct 06, 2013 | Amana Quiet Zone 12M12TA Air Conditioner
Not cool enough
What is the temp of the air copming out of it at this time depending on the room temp it shuld be about 15-20 degrees cooler than room temp
Jul 24, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
Water does not drain from my Amana quiet zone AC. It builds up inside, then causes rusty looking sedement to blow into my house. How/where is the water supposed to drain to the outside? Thank you, Bobbi
If this is a window unit it has to tilt a little to the back(outside) for the water to drain off the bottom back side. I am suspecting the unit is setting tilted toward the room a little. Look at that first. Hope I was of help to you!! Good luck!!
Nov 22, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Runs but doesn't cool
I would suspect the compressor is not coming on. Look at the capacitor they are dual type and one side could be out. Also how old is the unit check the thermostat quick way would be jump around it either one of these items would cause the compressor not to come on.
Aug 08, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Stop button does not work on amanda quiet zone room air conditioner
hi there,
if the stop button doesn't work,it continously run you can shut off circuit breaker for emergency shuting off.if this a proramable a/c unplug your a/c and put it back wait for 15 minutes .and try to run if still doesn't work your holding relay is shorted from control panel,try to call a service technician to check the actual control panel defective.have a nice day,don;t forget to rate me,thank's a lot.
May 26, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Blown fuse?
Is the display still showing anything? If the display is blank check outlet for power? If you have trip the circuit breaker, unplug the unit before you reset it. Set the controls to off. When the power is back on Trying running the fan first, then try the AC. The flashing may just be a max temperature reading.
Dec 28, 2006 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone 12M12TA Air Conditioner Logo
161 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Colin Stickland
Colin Stickland
John Tripp
John Tripp
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
