2003 Ford F250 Super Duty Crew Cab Logo
j
jason olson Posted on Jul 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replace the rear brake pads and rotors and slide pins but they still squell really bad had two shops look at it and they cant find anything wrong with it
Have put 3 different kind of pads in it and still does it
Thomas Perkins
Level 3:
  • Ford Master 15,088 Answers
  • Posted on Jul 08, 2015
Thomas Perkins
Ford Master
Level 3:
Answers
15088
Questions
0
Helped
3386462
Points
54869
Stainless steel slipper replacement is mandatory with the service brake pad installation, even if the slippers appear undamaged. Make sure the slippers are correctly positioned with the slipper ends snug against the outboard end of the anchor plate rail. http://www.mazdabg.com/ftp-uploads/Mazda/--Repair%20Instructions--/2001-2007%20Maza%20B23/MAZDA_B23_01-07_Ch9_Brake_Pads.htm
steve h woody
Level 3:
  • Ford Master 2,551 Answers
steve h woody
Ford Master
Level 3:
Answers
2551
Questions
10
Helped
504063
Points
10228
Hey Jason,ok sounds like you know what your doing ,when replacing brake pads and rotors on larger vehicles you need to break them in by doing 3 hard aggressive breaking events from 30MPH followed by 3 normal breaking events , this will cause heating of the pads and set the final hardening ,and curing , if you go to power nation a tv show they just did a short info on this .the only thing you didn't mention was the calipers and i'll guess there in exelant working condition ,at any point did you try anti squeal compound on the back of the pads,where thy meet the caliper cups.
Woody
Now I've changed rubber brake hose and hard line to the T on rear axle, bled system and left rear brake still drags. All new pads and rotors all around and new calipers in rear. And great pedal.
the callipers actually slide on two pins that are part of the mount to the axle. this sliding action allows the callipers to centralize over the rotor disc
if you are experiencing a dragging brake then remove the pads and see if you can slide the calliper on those pins
if not you will have to remove the pins and clean the rust and gunk out of the holes in the calliper
they do rust up and seize which gives dragging brakes especially after fitting new pads.
tip
Brake lubricant, why it's important to use the correct type
When replacing brake pads and rotors. Make sure to use the correct lubricant in the correct location. Slide pins should always be lubricated with a synthetic/silicon brake lubricant. Never ever use Anti-seize on slide pins, or anything rubber for that matter. Anti-seize will cause rubber to swell and cause slide pins to seize in the caliper brackets. Using any kind of lubricate formulated for brakes will prevent unnecessary repairs down the road.
You may use Anti-seize on any other metal to metal contact point. This means brake hardware that contacts the brake pad, the back of the pad where it meets the caliper piston and fingers, the hub face that meets the back of the rotor hat, and the pilot whole where the wheel centers itself.
Keep these tips in mind the next time you replace your pads and rotors and you will be on the road to success! Until next time, happy driving!
If you have any questions or need help while replacing your brake pads, trust a professional! Please feel free to contact me for advice on your current or next repair. Follow this link to contact me directly: https://www.6ya.com/eugene_aa01c1a9fa4c2ed9
on Mar 01, 2019 • Cars & Trucks
2000 monto carlo ss service tracking light comes on when i depress brakes and i notice rear brake rotors have deep groves and pad looks worn if i change both how will i no if calipers are ok
Your rear caliper is made to slide on it's bracket to allow your rear pads to move freely and evenly and to keep the brakes from dragging when not being used. If it won't slide on the bracket you can disassemble the two halfs of your caliper (when off the car) clean them up well (sandpaper, wire brush, brake parts cleaner, sos pads ect) and put antiseize or grease the slide pins. There are usually two slide pins and they have rubber gromets around them. If seized they may have caused the rear roters to wear badly.
3answers
WHy dose my brake pedal push back and make a grinding noise
Look through the openings in your front wheels and look at the front rotors-are they gouged up? You are probably running metal-to-metal, pads to rotors.
Chances are real good your rotors will have to be replaced along with new pads, but if you catch it early enough you might be able to have them machined, although nowadays that is hardly easy to get done and the savings usually is not as significant as it once was.
2answers
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
1helpful
Steps to replacing rear brake pads
A special tool is required to compress the caliper piston on the rear brakes-don't use a C-clamp on the piston.
Raise the vehicle and remove the tire. The rear calipers have only one guide pin. Remove this pin and raise the caliper. Remove the old brake pads. Using the special tool compress the caliper piston-the piston will have one or two slots on it. These slots must in the correct position to remount the caliper. Install the new brake pads and slide the caliper back over the rotor and replace the guide pin. If the caliper doesn't slide over the rotor you'll need to reset the slots on the piston. Replace the tires and you're ready to go.
1helpful
Change rear brake discs
  1. here is some instuctions on how to do the brake pad replacement this should help you out
  2. Jack up the vehicle on a secure metal part of the vehicle and place jack stands in the same area.
  3. 2 Lower the jack until the weight of the car is solely on the jack stands.
  4. 3 Loosen the lug nuts and remove the wheel from the vehicle, exposing the brake system.
  5. 4 Loosen the caliper slide pins from the rear of the caliper and slide the caliper pins out of the caliper.
  6. 5 Remove the caliper from the brake system and remove the old brake pads.
  7. 6 Secure the caliper to a part of the suspension with a bungee cord to avoid it hanging by the rubber brake hos, where it could be damaged or start leaking.
  8. 7 Loosen the two bolts that hold the caliper bracket to the vehicle and remove the caliper bracket.
  9. 8 Pull the rotor from the vehicle.
  10. 9 Measure the thickness of the rotor with the micrometer. Compare the measurement to the "minimum thickness" stamp on the rotor or the manufacturer specifications in the repair manual.
  11. 10 Take the rotors to a machine shop to have them resurfaced if they are above specification and need resurfacing. Verify the manufacturer's recommendations in the repair manual, as rotors do not always need to be resurfaced or replaced.
  12. 11 Reinstall the rotor on the vehicle.
  13. 12 Place the caliper bracket back on the vehicle and hand tighten the bolts on the back of it.
  14. 13 Torque the bracket bolts down to the manufacturer specifications in the repair manual.
  15. 14 Place a new hardware kit in the caliper bracket and set the pads in the hardware.
  16. 15 Press in the caliper piston with the caliper piston tool to allow the caliper to fit over the new brake pads.
  17. 16 Slide the caliper over the brake pads and reinstall the caliper slide pins.
  18. 17 Torque the caliper slide pins to the manufacturer's specifications.
  19. 18 Replace the wheel on the vehicle and torque it down to manufacturer specifications located in your repair manual.
  20. 19 Lift the vehicle off of the jack stand with the floor jack and remove the jack stands.
  21. 20 Lower the vehicle to the ground and remove the floor jack.
  22. 21 Press the brake pedal several times to pressurize the brake system before test driving the vehicle.
  23. 22 Drive the vehicle, performing several hard stops to make certain the brakes are operating properly.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
2005 yukon denali rear brake pad replacement> how to remove calipers? what bolts to remove? what size are they?
These use a seperate drum brake inside the rotor. The caliper will come off with the removal of 2 bolts. The caliper comes up, push the piston in using a "C" clamp or large channel lock pliers. Simply slide out the pads and replace as necessary. Use a silicone grease on the slide pins and on the back of the pads to prevent squeeks. Professionally I would use AC Delco pads. Anything else could create more noises and other issues! Let me know if you need diagrams or anything else.
4helpful
4answers
My rear brakes are getting way too hot on my 2000 Chevy Silverado. What could be causing this? I just replaced the brake pads and rotors. The back brakes seem to be seizing up and I can't figure out why.
This year of truck did have issues with rear disc brakes. Quality of pads is extremely critical. Go with the AC Delco pads and rotors to eleviate some of the issue. Make sure that the slide pins are liberally lubricated and move freely or drag will cause excessive heat to occur. Let me know if you need anything else.
3helpful
2answers
How to remove brake rotors on a 1996 ford explorer
How to replace the rear brake pads on a 1995 through 2001 Ford Explorer The system utilizes a drum-in-hat type rear brake rotor. The integral drum allows the use of a drum-and-shoe type parking brake system. All other components are similar to their front disc brake components Remove the two bolts on either side of the brake hose with the rubber boots. Do not remove the four bolts where the axle ties in. The two bolts to be removed require a 10mm socket/wrench. Loosen the pads from the caliper Rotor Removal In order to take the rotors off (replace with new or have them machined), it is best to loosen the emergency brake shoes. To do this, behind the rotors, in the back there is a rubber plug, remove that and you can use a screw driver to engage the teeth of the adjusting screw, turn it clockwise to loosen, usually 10-20 teeth. Usually this means turn it downward. After this, it may still be difficult to get the rotors off without tapping them. Use a rubber mallet and hit them from behind. Before really whacking the rotor, make sure you have loosened the adjusting screw enough. It may take heavy swings of the rubber hammer to do this. It will eventually break loose. Parking Brake You might want to check the parking brake while you are here. To remove:
  • Remove the rear disc brake rotor.
  • Remove the outboard return spring.
  • Remove the adjusting screw spring.
  • Remove the rear brake shoe hold-down spring and pin.
  • Remove the brake shoe adjusting screw and nut.
  • Remove the front brake shoe hold-down spring and pin.
  • Remove both parking brake shoes and the inboard return spring.
  • Check the parking brake lever for excessive wear and replace as necessary.
To install:
  • Position the front parking brake shoe to the backing plate and install the hold-down pin and spring.
  • Install the rear parking brake shoe with the inboard return spring.
  • Position the brake shoe adjuster screw and nut on the shoes and install the rear shoe hold-down pin and spring.
  • Install the brake shoe adjuster spring.
  • Install the outboard return spring.
  • Adjust the parking brake shoes and install the rotor, caliper and wheel.
  • Lower the vehicle and tighten the wheel lug nuts to 100 ft. lbs. (135 Nm).
ADJUSTMENT
  • Measure the inside of the drum portion of the rear brake rotor
  • Using Brake Adjustment Gauge D81L-1103-A or equivalent, measure the inside diameter of the drum portion of the rear disc brake rotor.
  • Subtract 0.020 in. (0.508mm) from the first measurement, adjust the brake shoes to that size
  • Adjust the parking brake adjuster screw until the outside diameter of the parking brake shoes measures 0.020 in. (0.508mm) less than the drum measurement.
  • Install the rear disc brake rotor.
Reassembly Reassembly is easy. Put new or machined rotors back on by sliding them over the lugs (they should slide on easily.) Loosen bleeder valve (having a catch bottle handy is good). Push calipers in slowly (using a c-clamp or large channel lock pliers), close bleeder valve. Put on pads. Lubricate metal clips with small amount of anti-seize. Re-adjust the emergency brake by turning the opposite direction from loosening. Refill the brake master cylinder
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
