Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Don't know where the hose hooks up
I have a frigidaire side by side refig and in the refrig area there is a water filter system that has a hose running from it down to the bottom of the refrig ..and the hose is just rolled up at the bottom with a tie around it.. where does this hose hook up at?
  • 66 Answers
You need a special coupling for that.
Get it at your nearest hardware store, though it usually comes with the in line filter.
Shouldnt be to complicated once you have the coupling - it's quite simple to figure out what goes where.
Good luck.
Posted on Jul 11, 2009
I am installing a reverse osmosis system in my home and need a "dummy cartridge" part to replace the water filter that is in the refrigerator - PureSource RG-100 and how do I get it?
hello.
i know such thing exist but i am having a hard time finding a part number for it. A alternative would be to in essence bypass the ref.filter this way.
The water line on the back of the refrig where the house plumbing connects to feeds directly into the filter first then out of the filter into the water valve to be dispensed to icemaker and door dispenser.you could connect the water supply from the RO system directly to the water valve instead of connecting the RO to the inline refrig filter.
Gene
Aug 06, 2011 | Frigidaire PLHS237ZD Stainless Steel Side...
Not getting water to ice maker and water dispenser
No model # to reference. Althou alot of issues might cause problems, some are really mondain. (e.g. is the valve on, has any plumbing work been done recently, if inline filter how old is it). Checking fill valve, access valve area, remove from bracket remove tubing and wire connectors from valve. Use jumper cord and power each valve solenoid put valve output ends in glass to test. If valve sends water from each valve if OK keep looking. If refer has internal filter, hook all back up to test. would need model # to give more help.
Ric
Mar 10, 2010 | Frigidaire FRS23R4A Side by Side...
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
No water at the dispenser
the water reservoir located in the refrig. compartment behind the drawers may be frozen,if nt the water inlet valve may be at fault.it is a dual valve system one side for the icemaker the other for the dispensor
Jan 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
My ice maker just stoped working I have another refrig at the camp that is the same refig I just never hooked up the ice maker how do I take them out of the frezzer and swap them?
ONE THING YOU CAN TRY IS POURING WATER IN THE TRAY--LET IT FREEZE--IF IT DUMPS IT OUT THEN IT IS YOUR WATER VALVE. IF NOT THEN REPLACE ICE MAKER
Oct 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispensor Quit Working
if you have water on the floor may be is the line if not water valve
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigator compressor motor
No fuse. Check for retracted pins in molex connectors in back. See if any pins are sticking up farther than others on side of plug where wires enter. If so unplug connector and push wire in. Re-connect and recheck. Also have seen this in connector in console on left ceiling of refig. section.
Nov 15, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
106 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
