Turning off the printer does not stop printing..and disconnecting from the modem hub does not stop after reconnecting.
You have a network printer and honestly, I've never used one so I'm just guessing is same prcedure used with a standard printer should work. Procedure is for Windows.
I mean, you should open Printers & Faxes item in your Control Panel.
Click on your printer and when it opens press DOCUMENT menu item.
Select CANCEL
This selection is supposed to cancel anything you are printing.
The "problem" is that printer has a memory buffer, so that's why it should continue printing it's content. I don't know it the indicated procedure should also cancel printer's buffer.
Buffer might be rather big. Just imagne the storing capacity of a "small" 256 Mb memory.
My second idea is to READ YOUR USER'S MANUAL. Just guessing, your printer may have, or better said, should have a reset fuction to cancel all printing operations, or something like this
You don't have the manual? Download it from here
ManualShelf Konica Minolta Magicolor Printer A034012 Magicolor 1650en...
