Question about Lenovo ThinkPad X60 Tablet PC
Lenovo monitor goes into power saving mode as soon as it turns on.
Samsung Tab A 8" tablet back button is not illuminated
Make sure the power saving is not enabled it shuts off that light
I figured it out. I was having the same problem. Is your power saving mode on? I turn mine on when I got it, then later realized my buttons weren't lighting up either. Just found out it was because of having the power saving mode on. Hope that helps!
Jan 02, 2018 | Samsung Tablets & eReaders
I have an RCA Tablet RCT6773W22 Android Version 4.4.2 The tablet is in Silent Mode.
I'm betting the volume switch is actually stuck and that the sound is just going down to "silent" the moment you release the "up" button. Does the sound get loud and just fade away? If so then that's probably it.
Feb 20, 2017 | RCA CA 7" Tablet with 4GB eory 28458515
Screen goes dim on start up ant i have to brighten it every time i startup
change under the control panel the POWER OPTIONS and set it up as you like and save on APPLY.
When you reboot is coming out bright
Mar 10, 2015 | Lenovo A10-70 TAB 8121/1.3 4C 10TCH 1GB...
Lenovo Tablet a8-50 is stuck in fastboot mode..can't turn on or off
if you able to take out the battery then remove the battery and reseat the battery, it will fix the issue (hope the battery has outside access). Hope it will help.
Nov 23, 2014 | Lenovo A8 50 8" Android 16GB 1GB
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
Cant install windows on lenovo X41 tablet pc
hi
you should check your hard disk may be there is a problem in your hard disk
May 04, 2010 | Lenovo ThinkPad X41 Tablet PC
On a seperate tablet PC I accidentally switched to dual clone mode but television, not monitor and now neither tablet nor monitor output works and it stuck in shut down saving mode, how can I restote...
turn the pc off and turn it back on, when it boots back up hit the fn key for lcd/external monitor until it works by turning it off of course i mean hold the power button down for 8 seconds
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 03, 2009 | ASUS R2H Tablet PC
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
Open Questions:
Lenovo ThinkPad X60 Tablet PC Logo
1,551 people viewed this question
Top Lenovo Tablets & eReaders Experts
Computer Links
Rajendra Singh
Rajendra Singh
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
