Question about Dryers
I have an LGR4364EQ2 gas dryer. As of today the timer has stopped working and there is no heat. Is the timer the problem?
  • Dryers Master
  • 3,361 Answers
The timer will not advance unless there is heat. Your problem could be a bad hi-limit thermostat a bad ignitor or bad gas valves. Open the burner access panel. Start the dryer on a heat setting and see if the glowbar ignitor comes on brightly. If so. It could be a bad gas valve coil or a bad flame sensor.
All these parts are relatively inexpensive and can replaced replaced by you.
Check the ignitor glow first and let me know what you find.
Posted on Jul 11, 2009
Kenmore Gas Dryer (Model #110.76022990) not heating and timer not working in Knit/Delicate setting. Then timer not working in any setting and still no heat. Talked with a repair man over phone and he said...
There should be a small plastic cover on the bottom left corner of the front panel so you can observe the burner assembly while it is running. Your watching for the burner to ignite after the glow coil heats up. It may work initially but after you leave the dryer run you may notice the glow coil on and when it cuts out the burner won't ignite. If this is in fact what is happening you will most likely need to replace the gas valve coils.
Jan 13, 2011 | Kenmore Dryers
Does not heat, automatic timer when out first
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 17, 2010 | Kenmore Dryers
The gas heat stopped today
heatman101
Jul 06, 2010 | Whirlpool LGR8648L Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Not heating
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Mar 07, 2009 | Kenmore Dryers
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
