Question about HP Office Equipment & Supplies
Print spooler not running
States printer not available. There are no printers installed. In windows control panel it shows the L7590 ready print spooler not running however when trying to print. In printer properties, it shows Pronter properties can not be displayed . The print spooler service is not running.
  • 3,741 Answers
To make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
thanks.
Posted on Jul 11, 2009
How do I config HP L7590 Officejet Pro printer to a wired network?
skil, your usb connection is to the cpu. Go to printers and devices from start and see if this printer is your default printer. If it shows ready, it's working. Test print.
Dec 01, 2014 | HP Office Equipment & Supplies
My officejet 6310 all in one printer has nt been working for past several days the report states that spooler has not running
Hello Richard! Welcome to FixYa!
If the printer report states that spooler has not running then there are few steps which fix that problem. Follow the given steps carefully:-
Click Start of your PC and open the Run Command and type the command as "Services.msc"
Then scroll down to print spooler services, Right Click and and select Stop
Now delete all your Print Jobs which are in pending status
Now go to C:\WINDOWS\system32\spool\PRINTERSand delete all the files or folders listed there, Now you can try to return to the Services.msc and start the print spooler service to see if this has been fix your problem
Be sure to stop the print spooler services before proceeding. First you must remove the corrupt drivers manually from the windows registry.
Delete your printer driver, now try to enable print spooler service again and Uninstall the Printer Software installed in the PC, Now again install the printer driver and software.Your problem will be solved.
I hope this solution helps you and you have a clear picture in your mind. Let me know if you have any confusion.
Sir, Your Rating as Five Stars and Words of appreciation will be esteemed.
Thank you for taking my service
Concerned: Muhammad UzairTeam : FixYa
Dec 16, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
My printer hp 1020 printer spooler is not running?
Reach to Hp tech support team, try this number (877-690-9305) might be helpful for you Support For Hp Printer Call Toll Free 877 690 9305
Aug 16, 2011 | HP LaserJet 1020 Printer
WHEN I WONT TO PRENT MY PRENTER TOLD ME THAER IS NO SOFTWER MY PRODUCT : oPTRA t 610 WHEN I WONT PRENT I TURN OFF & ON oR OBEN THAE DOOR
Default Printer Issue
The wrong printer is set as the default. See the image below for an illustration.
What to do
Open the Printers or Printer and Faxes folder and locate the correct printer icon. To do this:
    1. -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
      -In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
    2. Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
    3. Try printing again.
Topic 3: Printer is "Offline"
The printer is set to Offline and the printer icon appears washed-out. See the image below for an illustration.
What to do
  2. Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not Ready
The printer is in an "Intervention Requested" state (e.g. paper jam, paper out) but no Windows print error notification message is displayed.
Explanation
The print job cleared the print queue. This means the print queue icon has disappeared from the notification area ('systray') of the task bar. The printer is holding the job, however, until the the printer is returned to a ready state.
What to do
Check the printer LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do
    1. Double-click on the print queue icon to open the print queue. (This may also appear as a small printer icon in the lower-right notification area of the task bar.)
    2. Click on Printer in the upper left-hand corner of the menu bar.
    3. Is there a check mark next to Pause Printing?
      -If yes, click on Pause Printing to turn off this Windows feature.
      -If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler Issue
A problem with the Windows print spooler is preventing successful printing.
What to try
Stop and start the Windows print spooler. To do this:
  • -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
  • -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
  2. Click on the first job listed so that it is highlighted.
  3. Click on Document in the top menu bar.
  4. Click on Cancel.
  5. Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other Issues
Other possible causes of a print job not printing include:
  • -USB connection problem if locally connected only.
  • -Firewall issues preventing communication.
  • -Workplace virtual private networks (VPNs) preventing communication. VPN tunneling may be required to ensure successful communication. Enabling this feature may require network administrator approval and assistance.
  • -Document formatting.
  • -Driver settings.
  • -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last Resort
If you have tried all of the above suggestions to no avail, try the following:
  1. Reboot your computer and try printing again.
  2. Turn the printer off and on, and then try to print again.
  3. Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
Dec 14, 2010 | Lexmark Optra T610 Laser Printer
Printer is not working. There is no error light on and the ready symbol light is on. Nothing willnot print
Have you checked if there are any Documents Stuck in Queue to print ? ( under Control panel - Printer and faxes folder )
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone. ( Refresh the Printers and Faxes folder )
If this does not fix the issue :
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 03, 2010 | HP LaserJet P2015dn Printer
If printing and toner runs out can I delete job in process?
Yes you can
Open Control Panel - from START button
Open Printers and Faxes Folder
Highlight the Printer icon - Right click and click on Cancel All documents.
If this does not cancel.. try these steps below
Click on Run
Alternate method,
Click STart
Click RUN
Type
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio CL3500N Laser Printer How do I clear the print que from the printer?
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jul 01, 2010 | Ricoh Aficio CL3500N Laser Printer
How do I turn it on
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
Virtual Printer Deleted after Windows Update....I Can't printing MDI from internet page ((( Help please ... Office 2003 SP2 Had Before This MDI Printer very Good
First step, ( May be your print spooler service is not running )
1. See if you are able to find no printers at all in "printer and faxes" on control panel.
2. If not - go to start->run -> type "services.msc" and hit enter. Locate "Print spooler" service. See if that service is running on not. You might see "Started" in front of that means working. You can right click "print spooler" and restart once and check "printer and faxes" on control panel. If not follow step 2.
step 2:
You can reinstall the MDI printer by doing custom installation of Microsoft Office 2003. To do that follow below instructions
1. Go to Start->Run->Type "appwiz.cpl" and hit enter. This will open up Add Remove program wizard for you.
2. Now locate MS Office installation and click on "Change"
3. Check mark "add or remove feature" and click "next".
4. On the botton of the installation window check mark "choose advanced customization of application" and click "next"
5. Under "Microsoft office" expand "+" sign of "office tools"
6. Locate the object "Microsoft office document imaging". Click the icon and select "not available" and click on "update". This will uninstall the MDI drive.
7. Repeat the steps from point 2 and locate the object "Microsoft office document imaging" click the icon and select "run from my computer" and click on update.
Above steps will re-install the MDI drivers and you can find the virtual printer going to printer and faxes on control panel.
txsup
Mar 29, 2010 | Microsoft Windows Server 2003 Enterprise...
Print spooler error during printer installation windows vista
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Nov 23, 2008 | HP Pavillion ZV6000 Notebook
467 people viewed this question
Clive
Clive
