Question about Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard
Kingston KVR667D2N5/1G funciona como si fuera de 512M
Tengo una P4M800 Pro-M7 con 512M de ram. Si pongo solo la memoria de 1G, el sistema enciende reportando 512M y si pongo las 2, enciende con 1G.
  • sjmaldel Jul 11, 2009
    La P4M800 Pro-M7 tiene dos ranuras. Si pongo cualquiera de las dos Kingston, reconoce 512M aunque haya puesto de la 1G. Si pongo las 2, cada una en una de las ranuras, funciona con 1G, dejando de aprovechar 512M.
  • 413 Answers
Algunas placas madres tienen solamente 1 ranura de la memoria de funcionamiento aunque haya 2 ranuras en el tablero. Está usted usando 1 viruta o 2 virutas en la placa madre.
Posted on Jul 11, 2009
    New Friend:
I have a similar board P4M800-Pro-M2 and the two kingstons just do not boot, I updated the bios and it did not work too. I added a Samsung 512 Mb and a kvr667d2n5 1Gb and it worked reading only 512Mb from the kingston performing 1Gb, I tested them with memtest86 and reported no errors, but when Win7 enters standby the computer reboots. The mixed Samsung/Kingston worked only if the Kingston is on slot 1 and Samsung on slot 2. It seems to be a bad bios quality, not a board flaw. Some people said that a Pentium D-945 3.4Ghz and a single kingston DDR2 1Gb works for this board, maybe a better quality processor enforce the operation of the bios. Check the manual if your board can use a DDR (not DDR2) 400Mhz 1Gb Kingston, it is supposed that the original bios works for older memories. I want to know if someone know another bios of other board that injected can make this board to recognize the KVR667D2N5, be carefull because bios laboratorial experiments usually render your board dead forever.
Posted on Oct 24, 2013
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
Apr 22, 2011 | Nikon COOLPIX S8000 Digital Camera
No enciende solo tira una luz anaranjada atras de la carga
Hola:
1.- Desmonta la bateria (por debajo de la Laptop tiene, generalmente dos seguros, tira hacia afuera y se soltará la pila).
2.- Desconecta el cable de alimentación de la Laptop (eliminador).
3.- Intenta encenderla, dejando presionado el botón de encendido durante 15 - 30 segundos.
4.- Conecta solamente el cable de alimentación (sin bateria).
5.- Presiona el boton de encendido en forma normal.
Estos pasos sirven para descargar todo el circuito electrónico del equipo y/o desbloquearlo por alguna posible sobre carga eléctrica. Ve si funciona.
Si no enciende, intenta lo siguiente:
1.- Desconecta el cable de alimentación y batería.
2.- En la parte de abajo de la laptop, localiza una tapa con un ícono identificador tipo chip; desmóntala liberando el ó los tornillos.
3.- Retira el ó los módulos de memoria, jalando los seguros laterales de cada memoria. Tómala por los bordes.
4.- Limpiar o lijar los pines (contactos) de la memoria. Puedes usar un borrador de lápiz o una brocha impia y pequeña.
5.- Instalar un solo módulo de memoria, si fuera el caso.
6.- Encender la laptop sólo con el cable de alimentación.
Este procedimiento corrige una posible falla de lectura en la memoria que impide realizar el POST del equipo correctamente. Ve si funciona.
Espero y ayude. Gracias
Jan 31, 2011 | Acer Aspire 3680 Laptop
Tengo una memoria dim de 512 ram pero trato instalar una de128 comienza volcado memoria ¿ a que se debe?
En la mayoria de los casos este problema es debido a que los dos chips no son de igual velocidad.
Trata de instalar solamente el de 128 y si funciona estoy en lo cierto. Si no funciona entonces una de dos cosas sucede o esta da?ado el de 128 o no es para ese sistema. Saludos y suerte.
Dec 28, 2010 | Computers & Internet
Buenos dias tengo un problema con mi camara es una olympus con memoria xd picture card la prendimos y no podemos sacar fotos ni filmar nos aparese la palabra protec escr con signo de admiracion que puede...
Desde el menú de la cámara formatea la memoria.
Si no funciona, formatéala desde la PC.
Si no se formatea en una PC, la memoria está defectuosa. Compra otra.
Nov 09, 2010 | Olympus FE-240 Digital Camera
Enciendo esta me funciona el fan de micro pero no levanta el video
Pueden ser una de dos cosas.
1. Fuente de poder esta defectuosa y no produce el suficiente amperaje para todos los componentes de tu micro.
2. Algun modulo de memoria esta fallando.
Comienza removiendo los modulos de memoria, y conecta solo una.
Enciende la micro a ver si enciende.
Si no, sacala, y coloca otro modulo, y enciendela.
Si no lo consigues, prueba con otra fuente de poder.
Una de las dos es tu respuesta.
No te olvides de dejar un comentario si te ayuda esta respuesta.
Dec 27, 2009 | ASUS P5RD1-VM Motherboard
La tarjeta no me pita y no me da video
Una pregunta, cuando esta conectada la fuente de poder y enciendes el ordenador, el ventilador del procesador se mueve? Si no se mueve quiere decir que hay un problema de corriente.
Esto se puede deber a:
1. los cables/la conexión de encendido no esta bien conectada (eg. Los cables que van del gabinete a la placa madre)
2. La fuente de poder esta pagada, desconecta o defectuosa.
3. La placa madre no esta bien aislada. Es decir la placa madre esta siento “tocada” en sitios donde no debe. Eg. las monturas del gabinete están haciendo contacto fuera del las zonas aislada, o un tornillo/tuerca esta tocando la placa madre fuera de sitio.
Suerte,
Ed
Oct 04, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Mi Mainboard no reconoce 2 memorias a la vez
Your Motherboard has a built in Video display unit. This display is using 64MB of the RAM you would be using for other stuff. If you want the rest of the memory to be released you will have to purchase an Off-Board Video card that is AGP and then enter the BIOS screen on startup and disable the on-board video card and the memory (there may be a jumper on the MB to disable the on-board Video). I hope you can find someone to translate this for you.
Sep 12, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Jul 06, 2008 | 1994 Toyota Land Cruiser
Problema display
no me funciona una memoria de un 1gb que le puse me dice error y la pongo en el pc y la formateo y como quiera
Jan 15, 2008 | Vivitar ViviCam 5100 Digital Camera
Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard Logo
800 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Alun Cox
Marvin
Marvin
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
