Question about Microsoft Xbox 360 Console
My Xbox 360 was working fine and then when I turned it on again I had no audio or video. The only thing lit is the power light, no other rings. I replaced the audio and video cable but it did not help. Any ideas??
  • 6,784 Answers
HI, this is a GPU issue(rare Hardware issue). contact Microsoft for this repair asap....
Posted on Jul 11, 2009
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 elite showing no picture on screen...?? Have tried both HDMI and composite cables. Any suggestions
If the console turns on (you hear fans running and the ring of light is lit), possible issues may be:
1. TV is not on the correct input setting.
2. Graphics card failure (If under warranty, you should be able to send the console to Xbox for refurbishing).
3. Other hardware/software failure.
If the console doesn't turn on (No fans or lights), check the following:
1. Is the power brick plugged into a wall socket?
2. Is the Xbox plugged into the power brick?
3. Is the power brick LED lit? (If you answer no to this, the power brick is likely the problem.)
Mar 10, 2011 | Microsoft Xbox 360 Elite Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox 360 red ring
first of all, 3 red lights USUALLY means that you have an internal hardware error. microsoft has a garuntee that if your xbox DOES get the 3 red rings, you can send it in to them and get you xbox fixed or a totally brand new one for FREE. but before you do that, you should check ALL of the cords to make sure that they are plugged in right. there is a reported 33% of the Xbox 360 that were produced have a serious problem- once the motherboard reaches a certain temperature is bends, causing some solder balls to lose contact with the GPU and motherboard.
If there is anything that you want to be sure of before you take apart your XBOX 360 is assurance that what ever your going to do to it, is going to work!
just go to this website:
http://top3redlightfixes.com/XBOX3RedLights/xbox_360_3_red_lights.php?gclid=CIeBnJi1pJYCFQgRFQod0lsd7A
my friend used this site and got his xbox fixed in no time and he learned some suff too.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Wireless controller
I dont know if you have been able to figure out what the proble was with your 360, but the exact SAME thing happened to me. The 360 seems to be working fine, game loads, and both the consoles and the controllers rings lit up green, but then the controllers ring just keeps flashing and the console won't recognize it. I 've tried other controllers and nothing worked and obviously I tried to synch it with the console time and time again. PLEASE HELP!!!
Apr 03, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
