Question about Proform 325 Treadmill Walking Belt
I have a Pro-Form 320X treadmill. When the belt is moving, it slowly moves to the right side and hits the supporting brackets. If I don't stop the belt it will be damaged by the brackets. Is there an adjustment for this?
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Posted on Aug 29, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
SOURCE: treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
Nov 03, 2015 | Exercise & Fitness
Apr 17, 2014 | Proform Pro-Form 520 ZN Treadmill
Apr 05, 2013 | Exercise & Fitness
Apr 28, 2012 | Exercise & Fitness
Dec 10, 2011 | Ironman Exercise & Fitness
Oct 25, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
May 31, 2010 | Proform Exercise & Fitness
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
Aug 29, 2009 | Nautilus Tr300 Treadmill
Nov 27, 2017 | Proform 325 Treadmill Walking Belt
402 people viewed this question
