Question about BaByliss Dryers
Have went through 2 dryers and its still tripping breaker. House is only two years old. Could it be the breaker anyway? I don't understand how it could still be the dryer. Both dryers had to have the new 4 prong cord put on because it had a 3 prong cord. Could this even be the problem?
  • Dm007 May 11, 2010
    Firstly is the dryer on th ering main (with the rest of the sockets) or on a radial supply (its own trip ) And what rating is the mcb that keeps on tripping.
    Problem Solver:
  • 13 Answers
Yes. The four prong cords have inherent problems with their electrical consumption. The same thing happened to my lawn mower with a four prong cord. Try reverting back to a 3 prong cord, then, if that doesn't work, you really might want to have an electrician look at the wiring. Some houses are cheaply made, and the wiring is usually the first sign. If you have a prefab home, this might just be the problem.
Hope this helps
Posted on Jul 11, 2009
AFCI breaker will not reset.
Some breakers, when they trip, go into a state of limbo where the handle flops around but does not go to a solid off position. It may be necessary to replace the breaker.
Dec 16, 2013 | Electrical Supplies
Tip
Hi, Today my Frigidaire dryer quit drying. It's only a couple of years old! I...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Jul 04, 2009 | Kenmore 62602 Electric Dryer
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
Seem to all of the sudden have problem when dryer gets warm the breaker trips? anyone know why that might be.dryer has been on the same outlet for 2 years.
Hi, When a breaker starts to trip on any appliance, it is drawing more amps then the unit is rated for. It should have a double pole 30 amp breaker if it is a 240 volt dryer.The first thing I would check would be the breaker and the 2 hot wires feeding it. Over the years, the wiring sometimes loosens up due to heat and they may be loose and just need to be tightened up. If you turn the breaker off, it kills the voltage to the wires going into it and you can then tighten them. If you are not comfortable doing this, maybe you know someone that can help you out.Also, overloading the dryer with a lot of cloths will cause the breaker to trip. I am sure that after 2 or more years that you are aware of this, just another cause.You may also have a problem in the motor, which draw a lot of amps if it over heats.You may have a lot of lint build-up around the motor and heating elements that should be cleaned out by removing the back of the dryer. Be sure the power is off before though. Try running the dryer with no cloths in it to see if the breaker still trips.If it still trips, I would say you are loosing the motor, but would check the breaker anyway. Please let me know what you find.
Sincerely, shastalaker7
Oct 31, 2009 | Dryers
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer flips the breaker ran 4 1 year and nothing changed started this 2 days ago any idea about the
If its tripping your breaker either the motor is seized for some reason (easily tested by trying to turn the motor pulley by hand), or something in it is shorted out, most likely thing to short out and trip a house breaker is the heating element.
You can easily test the heating element as the possible cause by taking the 2 wires off the element connector, tape up these wires so it doesn't short out, plug the dryer in and try to run it. If its the heating element shorted out then the dryer will now run without tripping your breaker but of course not heat. If so replace the element.
Mar 09, 2009 | Kenmore 62602 Electric Dryer
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Dryer trips house circuit breakers when I turn it on.
Hello rarakaki,
I assume that you are referring to an electric dryer and that when you run it, it trips the main house breaker. If that is correct, then you may be running too many appliances simultaneously and that will draw curent , beyond the maximum rated value of your house main breaker. It is also possible that your main breaker may be going bad and tripping below it rated current value. I suggest you do the following: Shut off other appliances or electrical equipment in other rooms and then try running your dryer. If it operates and does not trip the main breaker , then the comments stated above are the problem. You may need to have an electrician replace your main breaker and/or change your service to a higher value. Please get back to me if I am incorrect in understanding your problem. Regards,
Rick
Dec 18, 2008 | Whirlpool Dryers
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
100 people viewed this question
Top BaByliss Dryers Experts
paul
paul
Tom Chichester
ray gallant
Are you a BaByliss Dryer Expert? Answer questions, earn points and help others
