SOURCE: garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
SOURCE: Pulling mechansm jammed on 1/2 hp craftsman garage door opener
You have a stripped gear inside the opener
SOURCE: Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
SOURCE: garage door opener does not work correctly
Make sure the door springs on the door are ok.Unhook the opener from the track by pulling the red handle rope on the track,make sure the door moves up and down freely.There is a up-force adjustment on the end of the opener that the small wires run to,you will see 2 slotted adjuster screws,find the one labeled up force,turn it clockwise a little bit(1/16th of a turn).Also there is a plastic gear inside the case that gets dry,unplug the opener,remove the 8 screws that hold the case on and lube it with a lithium grease,see if it is worn badly while you have the case off.
SOURCE: need a manual for sears model 139.18856, 1/2
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Our garage door repair technicians provide fast & friendly professional services across Oklahoma City including maintenance, installation, garage door opener repair and troubleshooting. Call now (844) 334-6701.
