Question about Transcend T SONIC 630 MP3 Player
When i try to charge my player with help of usb it is detected by the system.why?
    Sergeant:
  • 449 Answers
Because PnP (Plug and Play) BIOS of your system finds a new device attached to the system. Your system should detect it as an USB Drive when it will be connected to USB socket.
Posted on Jul 11, 2009
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
My computer cannot detect my sansa e250. When i connest the usb theres nothing happen, it only charging. Please help w/ this problem.
The power and data wires inside USB connectors are separate, so it's possible you have a bad cable.What operating system are you running on the computer?
Aug 14, 2010 | SanDisk Sansa e250 MP3 Player
Trancend pod not detecting
Go to Settings->USB
Under USB, you can see two options like, USB and MTV. Select USB.
Now Try again, it will work.
Cheers...!
Mar 15, 2010 | Transcend T.sonic 850 Digital Media Player
The mp3 player won't charge when I plug it into the computer and my wife's won't accept any more playlist
I dont know about the playlist. But if the Sansa LION battery goes too low it shuts down. When you plug it into your computer to charge the player, It usually powers up so the computer can detect the hardware being plugged into the USB port and provide power for charge.
You need to plug in the USB cable from the player to the PC and perform a system reset - Press and hold for 20 seconds the power on button and the play button (>||). this should work you may try it on your wifes player?
Feb 06, 2010 | SanDisk Sansa Clip MP3 Player
C250-Blank Screen,Not detected
Have you tried updating the firmware? I would try this first. You could have corrupt data, ( try on another system) reinstall USB software or upgrade (if used) make sure to completely uninstall first and reboot.
Oct 31, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My player charges but does nothing else
Try a different USB cable instead. Most likely a pin in the USB cable your are using is faulty and because of that your computer can't detect your player as the pin required for your computer to detect it is faulty. You can take a look at http://mympx.org for other users who have similar problems as well.
Jul 14, 2009 | Sony NWZ-A816 Digital Media Player
Willl not detect
go into settings on the main menu, then go to system settings then go to usb mode and take it off of auto detect and put it on either MSC or MTP
Feb 15, 2009 | SanDisk Sansa Fuze MP3 Player
My player charges but isn't being detected in order to add music
You don't have enough room on your drive to do this. I had the same problem. I took all my router ports off and connected just my creative vision player only and it worked. Computer system was over loaded.
Feb 11, 2009 | Creative Labs Zen Vision Digital Media...
Charging problem....
You might have a "bad" song? Try wipping the songs off and resyncing youre player. Also, for the charging problem. Are you charging it through your computer? I've found that these players charge ALOT better through an AC outlet. I hope this helps.
Sep 05, 2007 | Philips SA920017 MP3 Player
Transcend T SONIC 630 MP3 Player Logo
52 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
k24674
John Tripp
John Tripp
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
