Question about Garden
Engine cold starts, but loses spark once engie is hot.
I have a 20071 Recycler with the 6.5 Techumseh engine. It will cold start, but once the engine gets hot it loses fire. There is no spark until the engine cools. What is the issue?
    Sergeant:
  • 227 Answers
Have you checked the fly wheel? Can not have any rust present.
Mike
Posted on Jul 12, 2009
  • chelsey p
    chelsey p May 18, 2014
    yes and there was no rust
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Cold engine cranks when bumpping the starter once. After engine is wram you have to bump starter three time to crank. 1997 jeep wrangler 4.0 engine. What is the problem. Thanks
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Dec 17, 2012 | Jeep Cherokee Cars & Trucks
98 Buick Regal -engine quits
ok its one of two things you need to check when it cuts off if you have spark or fuel if you lose fuel pressure replace pump it gets hot and makes noise like its running but its not pumping fuel and if you lose spark you need to replace ignition control module has a hair line crack in it and when gets hot the crack expands and loses contact and wala no spark
Aug 15, 2009 | 1998 Buick Regal
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Will not start when engine warm
Sounds more like your ignition module is getting hot and not working. I'd go there first before replacing the ECM. You can remove the ignition module and most NAPA stores have the ability to test them for you. Make sure they test it at least 5 times. This way it'll simulate starting and stopping.
Jul 23, 2008 | 1991 Pontiac Grand Am
Garden Logo
139 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
