To release the Hotel ode, you have to get into its service mode option. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name and type of your device, in the search box [at the top right] of the home page; to get the related posts easily.
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
SOURCE: How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
SOURCE: i have a philips tv whith no remote from a hotel
If this has been a hotel TV then you cannot tune it in manually as the Hotel Mode will be activated & can only be re set to normal TV use by using a specific code from the remote control. The only other way is to re-initialise the internal memory using software that is only obtainable from a Philips dealer.
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
SOURCE: How to unlock AV on hotel tv philips HT5504/01Z?
mon tv mise en vielle apres toutes les 15 minutes
