Question about Canon ZR45MC Mini DV Digital Camcorder
Please help me fix my camcorder
When I press the record button it beeps and the screen goes black and then it goes back to the screen but it is not recording
  • 64 Answers
Re: please help me fix my camcorder
The record button is no good it happens on your model and the zr 500 and 600 as well needs to go to canon.
Posted on Nov 19, 2007
0 characters
3 Points
My camera's finger touch panel doesn't work when I touch it to play back the records, how can I fix it myself?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Movie recordng disabled
This is a disc error, have you tried other discs in the device? If you have information on the disc, you will need to try and recover from the RAW format that it is on. Did you try using a different type of disc when you got this error? Please answer my questions so I can better help you fix this problem
Jun 26, 2008 | Sony Handycam DCR-SR80 HD Camcorder
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
Panasonic PV-DV103 Playback Problem
check ur recording mode it may be on snapshotmode change it. or clean ur cam head
Jun 04, 2009 | Panasonic PV-DV103 Mini DV Digital...
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Zr65 question
go to canon website there is a recall for zr65 camcorders, they will fix it for free
Oct 17, 2007 | Canon ZR70MC Mini DV Digital Camcorder
It is good idea to check whether CCD imager is OK. Part number: A7031213A. Other possibble cause can be the optical unit. Regards, Arpi
Mar 13, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Canon ZR45MC Mini DV Digital Camcorder Logo
104 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
