Hiya, would suggest it is most likely one of the output chips (amp chip) is blown. Sorry but will need someone with experience etc to change the IC. Best of luck
Check the fuses, as well as your power connection and your ground. Make sure you have proper voltage into the amp. My main fuse to my amp had a bad connection and the amp wigged out much like yours. If all else fails your amp could be bad. If you run it at high levels for long periods of time it reduces the life of the amp due to natural heat damage. Anything that generates heat and or friction has a limited life span. The more heat it creates the shorter its life. You might need to take it to a shop and get it checked if all connections are good. and check the remote input.
