Question about Dell Inspiron 6000 Notebook
My power cord not charging battery
Dell Inspiron 600
My power cord even though plugged in is not charging the battery or sending power into the computer. I tried the cord on other computers and it still works. I tried unplugging it, removing the battery and reinstalling both, but nothing seems to work.
    Problem Solver:
  • 10 Answers
You may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Posted on Jul 11, 2009
Would like a circuit diagram for dell inspiron 1000 power circuit
There is a reverse polarity diode that prob popped. It doesn't allow the power to even reach the battery anymore. It'll prob charge in another laptop that takes that battery. The diode is on the mother board.
Nov 24, 2013 | Dell Inspiron 1000 Notebook
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Laptop wont recharge the battery
Even though you battery appears A OK, it most probably isn't, all one can do is check the power adapter, by replacement, OR trying another one, from some friendly soul, ... and/or replacing the battery,the same way...
Feb 21, 2010 | Computers & Internet
Inspiron 1521 won't charge battery or turn on when I have the power cord plugged in. The power cord is fine and is plugged into a an outlet and not a power strip. I can start the Dell MediaDirect up using...
I see possible failure as the following:
  1. The power control strip on the Palmrest Assembly (The actual button under the hinge cover)
  2. The motherboard, even though the system partially functions under the DMD button, that is a very limited function of the system
Jan 22, 2010 | Dell Inspiron 1521 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | Dell Inspiron 6400 Notebook
My Dell won't charge,
Sounds like the voltage regulator in the adapter is failing. Get a new charger...
Oct 12, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Inspiron E1505 - ac power not always on when plugged in outlet
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Jun 18, 2009 | Dell Inspiron E1505 Notebook
Dell Laptop Won't Boot Up
Don't take this as a definate answer, as I am only going on from what I've seen close friends do though I don't remove my Battery from my Laptop even though.
I do have some Electronic sexperience though very limited so my answer is You don't need a battery for a Laptop to boot and it doesn't matter if it doesn't hold a charge anymore,
Your problem I suspect is something else, meaning without proper (enough) input regarding what the Laptop does and or doesn't do, eg. starts the P.O.S.T then stops, 3 beeps or 1 , possibly none. Can you get into the BIOS setup? Maybe Windows starts loading and stops somewhere in the boot process.
If you need anymore assisatnce then feel free to ask.
Apr 09, 2009 | Computers & Internet
Dell Inspiron 9200 Battery defunct or ....
Try taking the battery out of the laptop, and see if it will power up. If not it is possible that your power cord died - and your battery may be just fine.
For reference, I've seen plenty of Dell's with dead power cables.
Jan 27, 2008 | Dell Inspiron 9200 Notebook
Dell Inspiron 6000 Notebook Logo
212 people viewed this question
Clive
Clive
Alun Cox
