posted by lovelymama on Nov 15, 2007
I have a BayCres sewing machine bought twenty some year ago from the Bay. Now this machine does not move at all but the motor is running. Where should I look at first? thanks you!
Michelle
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 06, 2008
manual handwheel does operate. motor runs but does not operate seger.
Best Solution
posted on Nov 15, 2007
Hello Michelle,
If you have an internal motor and you can actually hear it running I would check the motor belt first of all, if you can hear the motor buzzing then something is jammed in the machine.
Rating Locked! (?) lovelymama has rated this solution as Helpful
This Problem Also Relates To:
Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine
Kenmore 19606 Computerized Sewing Machine
Kenmore 744-10BH Mechanical Sewing Machine
Kenmore 756A-30BH Mechanical Sewing Machine
Kenmore 15202 Mechanical Sewing Machine
Kenmore 15358
Magic Stitch Mechanical Sewing Machine
Can you Help with these Sewing Machines problems?
Singer 7462 Mechanical Sewing Machine
the tenchon on my sewing
the tenchon on my sewing machen... Answer This...
Brother CS-8060 Computerized Sewing Machine
brother CS-8060
brother CS-8060
Were is the reverse sewing... Answer This...
White Sewing Superlock 2000 ATS Mechanical...
not sewing
not sewing
I broke a needle. Changed it. I... Answer This...
Singer CE-200 Quantum Futura Computerized...
canceling a transmission
I want to cancel a transmission... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
