Question about Kenmore 98702 Stacked Washer/Dryer
RATTLING & DRUM NOT SPINNING EVENLY, ALTHOUGH CHANGED BEARINGS TW
DRUM NOT SPINNING EVENLY AFTER CHANGING BEARINGS TWICE, NOW RATTALING AND MAKING NOISE, im sure i done everything right
  • 6,784 Answers
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Posted on Jul 11, 2009
Same trouble with mine. The belt looked ok ,it spun the drum but under load worked for a while then burned up . it had burn marks on the wrong side of the belt, oops check the grooves on the belt . a new drum seal, rear support bearing and belt about $ 75.00 still not the cost of a repair man to tell me it was broke...loads of luck......
Posted on Jul 28, 2009
Why is drum rattling?
Typically there are 2 reasons for this. Either, you have something trapped in the drum (Underwire Bra wires are the favorite for getting through the holes on the drum, getting caught near the bottom of the drum and making a horrible rattling scrape), OR your bearings are failing. If it's bearings then typically the noise will be far far louder on spin than on wash and you may have found bits of plastic and grey or greasy residue in your washing. This detritus will be from the grease in the bearings and small scrapings of the outer plastic drum, created as the inner drum, spinning erratically, catches it some of the time. If it's the latter, then sadly it's typically an uneconomical repair. Bearing replacements usually cost around £140, at which point you end up with an old machine, with one good part in it, which is questionable economics! If it is a "sealed drum" (that is to say, the drum cant be dismantled and the 2 halves of the outer drum are chemically bonded together during manufacture), then you are looking at the cost of replacing the entire drum, which usually works out at between 60%-75% of the cos of the machine when you bought it new.
Sep 23, 2015 | Washing Machines
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
When on spin,the drum is rattling and making a lot of noise
More than likely the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough, or is rumbling or grating, then the bearings have failed.
Dec 03, 2010 | Hotpoint WMA58 Front Load Washer
My Aquarius WF541 drum won't turn when I switch it on, although the motor seems to be?? I've cleaned the filter, and got 2 coins and what looked like metal filings, but they may have been plastice, seems...
Try turning the drum by hand from the front of the washer, if it feels rough o ris grinding or rumbling, then the main drum bearings have probably failed, also try lifting the drum up and down from the front, see if there is any movement of drum, if there is, then again it is a main bearing problem.
If all o/k, then remove the lower rear cover, and check the belt is o/k.
Nov 29, 2010 | Hotpoint Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
243 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
