Question about D-Link AirPlus DI-714P+ (DI714P) 802.11b
Using a printer attached to D-link modem
My wireless laptop won't print to the printer attached to the DLink 714P+ but my wired pc will. What do I have to do?
  • Anonymous Dec 19, 2007
    I can't connect to internet through the router. My internet connection is find when I go straight to the modem, but even with cabled connection to router, it doesn't work.
  • 41 Answers
Is the printer connected to a computer which is connected to the router or is the printer set up to be a network printer?
Posted on Nov 19, 2007
I have a d link d1 514 router. I'm unable to open if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Can't figure out how to connect my printer to the "network"... hope I'm using the right terms. Had it all set up to a dlink wireless router with a modem and had to disconnect it all to resolve another...
connect a lan wire from router to printer
print printer information
find out ip
pls add static ip address on the pc(printer and pc should be in one network)
type ip address on the internet explorer
change the ip address of your router class ip network range
remove static ip from pc
Oct 28, 2009 | Brother HL-2170W Mono Laser Printer
Is there any advantage using my DLink DIR625 with my Verizon 9100EM modem/router set up using WPA2? I have one ethernet tethered desktop and one laptop, plus using an wireless Skype Ipevo phone on the...
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
Jun 27, 2009 | Computers & Internet
Please explain how to connect LinkSys D-Link wireless broadband router Model No. DI-713P with Comcast broadband modem and Dell OptiPlex 360 Desktop? I am using Windows XP-Pro. Thanks, dana
What is Comcast Modem's Model?
if your modem is not a Modem Router:
here is the link where you can download the manual...Mid left of the web page.
if you have Modem Router?
Bridge your Dlink router by changing the IP Address of Dlink Router and connect it wired to the LAN port.
send me your email add so that I can send the instruction How to install.
Mar 20, 2009 | D-Link DI 713p (DI-713P) Wireless Router
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from to save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
DI 624 Wireless Broadband Router
So- Red - First of all don't rate yet. This will probably take a couple notes. So, let me make sure I've got this straight:
Modem>>>>Linksys>>>>DLink( no status or pwr lt)
v v
ptr ptr
Is this crude diagram about right? Are the ptrs wired or wireless?
How many pcs? Wired or wireless? Getting their ip from which router? Linksys model #? Operating systems?
May 14, 2008 | D-Link AirPlus Xtreme® G DI-624 Wireless...
D-Link AirPlus DI-714P+ (DI714P) 802.11b Logo
81 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
