Please add more detail. Does it show that code when the cycle is running? Can you start a cycle? Is anything else displayed? Have you tried unplugging it and plugging it back in? FDL might stand for front door lock. Can you open the door? If so, maybe the lock is broken and needs to be replaced. Like I said, please add more detail.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name and type of your device, in the search box [at the top right] of the home page; to get the related posts easily
SOURCE: Whirlppool front loading washer won't start, code FdL, door can be opened
"Fdl" is a door latch FAILURE error code. What the error is telling you is that something is malfunctioning with the electronic door latch and/or interconnecting wire or Central Control Unit. It is recommended that you check the wiring harness connected to the door latch or, replace the door latch. The following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions or concerns please post back and let me know. I hope this helps you.
SOURCE: washer will not drain or run. It gives a code nd
pull back off washer and check your waterpump
SOURCE: FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Testimonial: "Very quick answer.......even better was it solved the problem. Thanks"
SOURCE: fdl code washer wont start
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
