Question about GE Dishwashers
Water left in bottom dishwasher and after resetting to wash will not start unless the water is drained out manually
  • 224 Answers
GE Dishwashers are equipped with an anti-syphon ball that generally dislodges itself and goes into the drain line. To remove it, you'll have to pull it out of it's hole. Turn the supply off and open the kick plate. Remove the supply line from the dishwasher and the drain line free from the air gap. Remove the two screws that hold it to the counter top and pull it out. Remove the lower rack and spray arm. To remove the spary arm you have a 1/4 inch head screw to undo, and on the back of the spary arm is a plastic clip. Use a small screwdriver to depress from the spray arm and pull the spray arm off. There are then two 1/4 inch screws that hold the food screen on and remove the basket. Now, underneath the dishwasher is a large manilla-colored hose with a large hose clamp that must be loosened. Pull this loose and a bit of water as well as the ball will come out. Reattach and drop the ball into the left hole under the basket. Reconnect everything and slide the dishwasher back in. Reinstall drain hose and supply line. Turn on supply. Run and look for leaks.
Posted on Jul 11, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and...
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
May 23, 2017 | Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
After using my dishwasher,there is water left at
check all filters inside the dishwasher something is blocking the outlet hole,but also remember all dishwashers have about 1 inch of water left after a wash so check between washes.adrian;;;
Jan 20, 2010 | Dishwashers
Not cleaning fully - tablets left in bottom of unit - some of runners on bottom tray missing
Well first of all you can check the Water-inlet valve
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need replace it.
After then you can check the Drain valve,  that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Please post comments if you need more help or information..............
Good Luck!!
Thanks
Jan 07, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Water left in the bottom of dishwasher after cycle was complete
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Aug 27, 2009 | Frigidaire Dishwashers
Water left in bottom of dishwasher when finished, cannot start a new washing until water is removed manually.
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Jul 11, 2009 | GE Dishwashers
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not draining
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
Mar 05, 2008 | Dishwashers
Dishwashers Logo
757 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
