Masterbuilt 20070106 Electric Smoker Logo
D
Don James Posted on Jul 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I go to set temp & time why can't I read digital readout numbers?
johnny rebel
Level 3:
Top Expert:
  • Masterbuilt Master 10,875 Answers
  • Posted on Jul 05, 2015
 johnny rebel
Masterbuilt Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2939635
Points
47944
How can I stop the Samsung gusto 3 from reading numbers of incoming calls.
I believe one of the Accessibility Readout options is enabled. From the home screen, press the Left soft key. Select Menu, then Settings. Go to Accessibility and then Easy-Setup. Check that the following are off: Full Readout, Digit Dial Readout, Alert Readout. (Alternatively, you can look at each of these individually from the Accessibility menu.) There may be other options to check in the Readout options but these seem the most likely.
I hope this helps.
CANT GET WATER TEMPERATURE READOUT
That is because MP3 & Digital Media Players don't do that.
Try the correct category and what are you trying to get a water temp reading from? Brand name and model number would help.
Wherer is the temp sensor?
Does the readout read the temp of the discharge air rather than the room temp?
Sub zero 690 control center readout
A picture would be helpful, but there should be two 2 digit numbers. the one on the top should be fridge temp reading somewhere around 34-40, and the bottom one should be freezer temp, reading around -2 to 05.
2answers
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
76helpful
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 • Watches
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Change the digital read out for time and charge.
There are actually two hidden buttons that you cant see below the start button... Change the amount to what you prefer and press the hidden button across from the low temp. button twice.
Hope that helps, Mike
Nov 19, 2008 • Dryers
2answers
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
Top Masterbuilt Grilling Experts
Paul Carew
john h
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
