I suspect something is causing the pc board to fail but I see no indication of overheating/burns/blisters except for a chip out of the to end of the black cover of this relay -(http://pdf.datasheetcatalog.com/datasheets2/69/69039_1.pdf) in the RY-YV labeled location. I can supply pics. The board = XXYD-M V1.5 2004/03/03 I am thinking about ordering a replacement pcboard but before I did, I wanted to get some feedback. I would like to know if there is anything else I can check and eliminate to be sure this is the part required. Also, I tried to find this board (https://www.encompassparts.com/model/DBYDPAC9030/_/_/Danby/DPAC9030/PORTABLE_AIR_CONDITIONER) but am not 100% as to which one it is listed. Please confirm if it is A2516-710. Thank you for any consideration and time. I am a disabled person who tries to learn and do as much as I can and really value any help that can get my A/C on again. FYI, I am near Vancouver BC. I was going to order the part online or through Amre unless you can offer a better service. Thanks again!! :)
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
SOURCE: My unit is flashing a
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
SOURCE: Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
