Question about Maytag Neptune MAH5500B Front Load Washer
Gfi installed yesterday on washer 120 v outlet. washer is maytag 3 years old and gfi began tripping during washcycle. can it be washer 3 pronged cord is not grounded at connection in rear of washer? what else could cause tripping? is this a safety hazard? fix ?
The ground not being connected does not tirp thr gfi. The gfi senses the current between the two legs it will trip when the current returning to ground (neutral) exceeds 5mili amps. This is for personal protection. If you have a gfi circuit breaker disconnect the black wire from the breaker, if it does not trip you likely have a groung fault in the washer. If you have a dryer or other metal object that is grounded (Bonded) you may get a shock from it, also standing (barefoot) on a concrete floor may cause the same. ( bonded is a gronded conductor that attaches all metal parts of a electrical curcuit together) a hot lead goes to ground is a dead short and will trip any breaker.
Posted on Jul 13, 2009
When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Apr 03, 2015 | Heating & Cooling
How to stop my whirlpool washer from tripping gfi
If it is tripping the GFI I would say you have created a short somewhere. Check that wire has not been braised, check the plug for signs of burning, check outlet for signs of burning. Plug another device into the outlet to see if something else trips the GFI. If something else trips it then you could have a bad GFI outlet. These are the basics to try first but could be a number of things beyond this.
Aug 31, 2012 | Whirlpool Washing Machines
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
GFI switch outlet may have damaged Kenmore 55771 side-by-side?
Could be the GFI switch.
The washer has a 3-prong (grounded) plug, what about the other appliances that you tested?
The GFI may not have a good ground and the 3-prong appliance provided a "difference" that the GFI detected as a "fault".
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
The washer fills just fine, but when it starts to agitate, it trips the GFI outlet. It's not the outlet, we tried 3 of them. The washer works just fine if it's plugged into a non-GFI outlet. Any ideas?
I do home inspections, and this is a no-no! GFI devices are not real happy with inductive loads, such as motors and refrigerators. Generally during home inspections, we find that GFI's older than 10 yrs. have a 75% failure rate using a sophisticated tester. The 5 yr. old devices are at 50%. I'd replace that outlet with a single outlet, dedicated to the washer. If it's near a sink, then you're required to stick with the GFI. I'd just repalce it with a new one. Good Luck!!
Jun 11, 2009 | Whirlpool LSR5132PQ Top Load Washer
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
256 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
