Question about Air Tools & Compressors
I turn on my Coleman Powermate Inflationmate and the tank doesn't fill with air (but the motor runs. Is there an adjustment to make to start the tank filling?
  • 98 Answers
Needs valves rebuilt in the head of the compressor
Posted on Jul 21, 2009
Coleman powermate compressor wont start. It has always ran fine. Went out and the tank has no pressure. Everything looks Ok, but it wont start. Doesnt even make a sound. There is power at the plug in. ...
Two main things to check are the motor circuit breaker and pressure switch. Without knowing your model number I don't know exactly where to tell you to look but somewhere on the electric motor, or plastic housing if it's remotely mounted, there should be a reset switch/button. They are usually red or white, sometimes black. Push it in and see if the motor works. If the breaker keeps popping off there is something making the motor work too hard like bad bearings in the motor or pump, piston/cylinder issues, etc. To check the pressure switch, unplug the cord or turn off the circuit breaker. Remove the cover on the pressure switch and find the wires from the cord and motor. You can jump them on the switch (black to black & white to white) or disconnect them and connect the two black wires together and two white wires together. Turn on the power and if the motor turns on it's the switch if not it may be that your motor is burnt up inside. Don't let it continue to run like this because it will overfill the tank to dangerous levels without the pressure switch wired in.
Jan 28, 2012 | Coleman Powermate 27 Gallon Air Compressor
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate Inflationmate portable 4 gallon compressor. Model VP0200406. See image at http://www.yotatech.com/f5/how-fix-compressor-111315/ . Coleman lable on back says 120 v, 15 amp, single phase,...
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 20, 2009 | Air Tools & Compressors
Can't start coleman powermate 500 generator
I had one of these and it was very sensitive about getting the carb jet plugged up from leaving gasoline in the tank and carb bowl. I had to take it apart and clean it w/ card claener several times. I can tell you the engine is super sensitive ab out the needle jet setting. Too rich or too lean and it won't run at all or will gas you out from the smoke.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
My coleman powermate generator won't start
any small engine repair center, where are you located. have you tried to drain the carb bowl and filling tank with fresh gas?
Jan 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
202 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
