Question about OfficeMax 0M96431 Shredder
Paper got stuck. machine will not turn on. - OfficeMax 0M96431 Shredder
    President:
  • 1,273 Answers
First, check that the machine is properly seated on the waste container. There is a switch that prevents the shredder's operating if it isn't properly seated. Will your "ready" indicator light up? If the machine will not turn on at all, try something else in the outlet the shredder is plugged into. If there is no power to the outlet, you probably tripped the breaker. Reset it and proceed as follows. Turn your switch to "off". Unplug the shredder and flip the shredding head upside-down on a stable surface. Remove anything that was previously hanging down. Gently remove stuck stuff, keeping your hands in a safe position. Place the shredder head back on the waste container and plug it in. Most all shredders have a reverse on them for just this occasion. Work the machine reverse and forward, until it releases. When in reverse, remove whatever the shredder gives up, with the switch set to off, of course. This should get you back in the shredding business. Next time you're at one of the office supply stores, get some shredder lubricator sheets. Using these from time-to-time lessen the incidence of jams.
Enjoy! --W/D
Posted on Jul 11, 2009
Sharp copier
1) turn machine off or on
2) get a flashlight and look for torn pieces of paper wedged anywhere in the paper path
3) clicking indicates that something is trying to turn but cant because it is stuck
4) dust on a photo sensor
5) broken flag that activated the photo sensor
6) look for turn knobs or release tabs that will let you ease paper out of the machine. Yanking on the sheet with brute force is always a bad idea because the sheet tears and always leaves something behind to get stuck
Aug 23, 2012 | Sharp AR-150 Toner
Obstructed copy
Typically when labels come off the paper, the get stuck on the Fuser (the heating rollers just as the paper exits the machine) Open up the printer and turn the round hand that you would clear a jam with, and look on the roller to see if they are stuck there.
They are also known to get stuck in the paper tray or pickup assembly. Follow the paper path through the machine and you will find them.
Good Luck
Jun 03, 2012 | Canon ImageRUNNER 330s Copier
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper stuck in printer,can't get it out.
(1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
(A) When printing from the Auto Sheet Feeder
(B) When printing from the Front Feeder
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
May 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 05, 2010 | Brother IntelliFAX 1820C Plain Paper...
It say paper jam and ther is no paper jam
Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
It says paper jam, but there is no jam
Dec 17, 2009 | HP 1010 Plain Paper Inkjet Fax
My fax machine says pls open cover
Very likely you have some paper stuck in the printer. Try to lool for it and remove the stuck paper
Jan 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Paper
Note: Turn Off the machine for Safety Used.
- Check the Fuser Assembly if they have a pieces of paper stuck.
- Reinsert properly the Toner Cartridge Assembly.
- Check all sensor if they have a pieces of paper stuck or dust.
- All assembly and door covers needs to properly inserted.
Let me know if the machine is working?
Jun 17, 2008 | Sharp AL-1655CS Copier
OfficeMax 0M96431 Shredder Logo
569 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Randy Schumann
Randy Schumann
Tom Chichester
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
