Question about Cutler Hammer Cutler-Hammer No.BR816L125SDP 125A Lug Load Center
Each of the black switch is a removable unit. What is in the unit? Does it have a fuse? I found that one of the switch is supplying power to the furnance and I measured at the furnance end that there is no power. But the breaker switch was not tripped. Is there such thing as the switch is broken(fuse in the box)?
  • 142 Answers
Breakers do wear out and need replacement
Posted on Jul 11, 2009
I cannot get the unit to switch on, I have changed the fuse, removed all cables
Was the fuse you replaced blown? Has AC outlet on the wall been verified to be working properly? If outlet works, modular type AC power cable found to be properly seated and fuse was "OK" you've had a power supply failure that requires shop service.
Mar 27, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
How do I Turn it on
The power switch is on the left side of the machine near the back of the machine.
Assuming that you found the power switch, if nothing happens when you flip the power switch, chances are that you have a blown fuse.
1. First be sure that you unplug the machine!
2. Remove the "Platen" (the big black roller that the paper wraps around) there are clips on both side of the roller. NOTE Which side of te platen has the gear, this will be important when you reassemble it.
3. Turn the machine over and remove the 4 screws in the bottom.
4. Turn it over again and remove the top
5. The fuse is located in the power supply (where the power cord goes in the machine)
6. Replace the fuse with one of the same rating. Fuses can be bought at electronic supply stores (like Radio Shack) or at some hardware stores. Take the fuse with you to be sure that you get the same size physically and that it is rated the same as the old one.
7. Reassemble the machine be reversing the procedure.
Dec 17, 2010 | Brother ML-300 Typewriter
Is there a common power issue with Magnavox Model 42MF337B
u have the main switching power supply unit blown. fuse will immediately blow as u have mentioned. they all use smps (switched mode power supply system).  it may be concealed under aluminium plates or cover. look for a  transformer with yellow insulation tape covering near the ac mains input. it is a high frequency tranformer with solid ferrite core. near it there should be the main switching section with a heat sink attached.
Apr 13, 2010 | Televison & Video
99 town and country quit now even the warning lights dont come on
from ignition switch
key to run
black/orange power to fuse 11 and 12 in junction block and fuse 1 in power ditribution center
power to
black/white
dark blue
dark green/red
power all times
pink/black
red
pink
gray/black
check the maxi fuses
Mar 13, 2010 | 1999 Chrysler Town & Country
Was working fine. started burning ac line fuses and noticed a little smoke. I found a bad light switch going to the ac outlet it was plugged into, which I think has caused this whole problem. removed the...
u have a shorted primary power supply unit on your amp. for linear supply check diodes and capacitors. for smps chek switching transistor or any other switching component. if u have no idea get it repaired by a tech.
Jan 30, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
Dell power supply NPS-210AB will not turn on
Try switching it with one that you are certain works just to make sure it didnt blow or that your computer is working alright. or, using a multimeter, try and check for any current flowing to any of the connectors...
Jun 21, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
THE COMPUTER IS NOT WOKING
Check the power cable/cord for continuity with your multimeter ok. Make sure also that the mains or power outlet is giving the right voltage. This is also done by the use of the multimeter - either analog or digital - any one at your disposal can do ok. if all work well, then the power supply unit should be removed from the system unit, connected directly with the power cord and then bridged. That is at the secondary output which connects to the system motheboard. Locate the power-on cable(normally green in colour) and bridge it with any black cable on the same row. The cooling fan at the back of the power unit should be rolling if the unit is ok. Good luck
Jun 03, 2009 | Compaq (243890-001) 250-Watt Power Supply
Have a honda odessey 2000. needs a new DRL relay; but cant find it under the dash _any ideas _
the daytime running lights control unit is behind the glove box. You must first remove the glove box to access the control unit. However, the fuses that supply power to control unit functions are accessible in several fuse boxes. the No. 3 and 8 fuses (15A) and No. 14 fuse (40A) in the engine compartment fuse box, the No. 5 fuse (7.5A) in the driver's kick panel fuse box, and the No. 6 fuse (10A) in the passenger's kick panel fuse box all supply power in some way to the DRL unit. Other inputs that can affect the DRL system include a faulty parking brake switch, faulty combination light switch, faulty headlight relays or blown bulbs, and even the brake fluid float switch.
Apr 04, 2009 | 1997 Honda Odyssey
Accordianman--Dual deck VCR not responding...
No. Sound like the Switch mode power supply is or has failed, to repair this would involve replacing capacitor and or some componets, Many repair shops these days have discontinude repairing VCR's becuse most of the time you can replace the entire unit for the cost of repairing it
Feb 24, 2008 | Televison & Video
Pc won't turn on
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
Sep 07, 2007 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Cutler Hammer Cutler-Hammer No.BR816L125SDP 125A Lug Load Center Logo
104 people viewed this question
Top Cutler Hammer Hammering Experts
John Trevino
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cutler Hammer Hammering Expert? Answer questions, earn points and help others
