Question about Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router
Cant Connect i am playing xbox 360 using a eficient netoworks router and it seems that i cannot connect to alot of my friends. It says unable to connect to host. i was wondering if there is a possible way i need to switch my ip adress because every once and i while i can connect and then it goes back to this . what is the problem how do i fix it!! plz help!!!
    Scholar:
  • 94 Answers
Try setting your MTU settings to 1500 or higher. Visit
www.speedguide.net/downloads.php
then download the TCP Optimizer. this software should optimize your internet and set your MTU for the proper settings.
http://www.speedguide.net/downloads.php go here and download the tcp optimizer. It should optimize your internet to 1500 MTU.
Hope this helps, have a nice day! ^_^
Posted on Jul 11, 2009
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
Xbox live connection error
Make sure your NAT is set to open. If it's restricted you may not be able to connect to alot of your friends or games. You can change this by accessing your router through an internet browser.
Apr 10, 2010 | Actiontec GT704WG Wireless Router...
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
X360 and PC connect - Laptop doesnt!
Looks like you may have WEP security on router and WAP on laptop - or vice versa. Change the laptop to match the router.
Oct 23, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Cant connect to live...wireless.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
Jan 22, 2009 | Microsoft Xbox 360 Console
XBOX 360 Wireless Adapter Question
When i try to play halo3 with my friends i get the same problem. I cant connect to them and sometimes i also cant hear some people talk. Some problems might be that your NAT is set to STRICT or MODERATE you will want it to be open to play with your friends. I dont really have an answer but you will need to get in your apartments router to change the settings to get the NAT to become open. If you type in on the google search bar: Cant connect to friends on xbox live there will be some answers for this problem.
Jan 14, 2009 | Microsoft Wireless Network Adapter Xbox...
Cant have private chat or play games with friends
This should solve your problem
For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
The following ports must be available for Xbox Live to operate correctly:
� UDP 88
� UDP 3074
� TCP 3074
To open the ports on your router see this handy website here,
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
which gives you a step by step guide.
Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
Once the correct ports are open for your Xbox 360, then your NAT should say open.
Nov 26, 2008 | Microsoft Xbox 360 Console
Communicating with friends
It could be a NAT problem, your router could be configure with high firewall settings using NAT, so you should try to connect to your router and configure it to allow all incoming connections (could be dangerous if you use your computer without antivirus or antispyware). It all depends of the model of the router and also ISP (some put very strong firewalls settings for their routers so your machine can be safe on the internet). The NAT firewalls allows you to send but not receive, so went someone try to play with you, it says unable to connect with that person.
Aug 26, 2008 | Microsoft Xbox 360 Console
Not letting me except game invites on xbox live
The unable to connect problem is because NAT problems with your router, you'll have to configure your router and the NAT firewall to accept any income to you local network. Depending of the model of your router you'll have to use a computer to connect to you router and then configure it, so you can disable the firewall or put it to minimun.
Aug 19, 2008 | Microsoft Xbox 360 Console
Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router Logo
293 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
