Question about Kenmore Dryers
My dryer will not cut off and the dial doesn't move.
  • 6,784 Answers
HI. you will need to replace the timer control module. it has failed at this point. the timer motor is not able to properly advance the knob, in return, disrupting the normal sequence of your unit.
Posted on Jul 11, 2009
The dryer is running, but it has no heat. When you place the dial on 30 minutes it doesn't move at all, it just stays on the number. It does run and move the drum around, but no heat at all.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 05, 2011 | Dryers
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dial on the GE dryer does not move. but clothes dry
the dial on my ge dryer does not move, but clothes dry
Aug 03, 2009 | GE DVLR223 Dryers
Dryer does not heat
when your dryer does not heat the timer will not advance, check the heating element and the thermal cut out kit
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Dryer will not turn off. dial does not advance
You need a new timer. The cam (dial) is round with different cuts in it. When the cam advances, the keys, like a piano, will make contact with the cuts. If the dryer is not advancing, then the timer has gone bad. The contacts are staying closed keeping the switch of the dryer on. This is a VERY easy part to replace... No need to hire anyone. I can walk you through it.
Feb 23, 2009 | Dryers
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
