Question about Nokia 5800 XpressMusic Smartphone
My 5800 turns on&off repeatly
When i press the turn on botton, it becomes on & off repeatly. even i cant see the nokia logo, just a white screen becomes on & off.
How open code security factory setting Nokia 5800 Xmusic, Restore all original phone
HARD RESET in Nokia 5800 XpressMusic Smartphone
Please Note:
The result of this process will wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it.You are advise to make a back up of your device and you need to understand that what you are doing this is at your own risk. We will not be held liable for any type of loss that may occur during the reset process.
For Hard Reset;
-Turn the Phone Off
-Press and Hold ANSWER + REJECT + CAMERA keys simultaneously.
- Turn ON the phone by pressing the Power Button
- Wait for the handshake / Nokia logo appears.
FOR SOFT RESET
For Soft Reset;- back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your Nokia X6, 5800 XpressMusic back to all previous settings
From menu:
Settings>Phone>>Phone Management>>>Factory Settings
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 would not turn on the buttions light up thats it
Your phone's software is corrupted. Try to do a hard reset. While the phone is off. Press the green call key, red key and the camera key. While holding these keys turn on your phone. Don't leave the keys untill you see the nokia logo.
If it doesn't work you have to get your phone flashed.
Thanks for using FixYa. Please rate the answer.
Aug 05, 2010 | Nokia 5800 XpressMusic Smartphone
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 xpress camera turns blank , cant take images
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
thanks.
Jul 08, 2010 | Nokia Cell Phones
My phone is showing only the startup NOKIA screen, tried removing battery several times.
try to do a hard reset on your phone,
remove your sim and memory card, but please be aware that this will erase your user settings once a successful hard reset had taken place.
try doing this trick if it will work on your phone.
1. turn off your 5800 phone
2. press these keys, green key, red key and camera keys and turn on your phone without removing your fingers from the keys.
3. keep pressing until you see the nokia sharing hands logo.
regards.
Mar 06, 2010 | Nokia 5800 XpressMusic Smartphone
I have nokia 5800x and it gives me a massage "faild to start up please call your retailer"
I don't know if this will help that but give it a go.
Nov 23, 2009 | Nokia 5800 XpressMusic Smartphone
How can i format my nokia 5800 phone memory ?
The Default code is still 12345, of course...
Do this if your device is not turning on properly or better yet bring it to your nearest Nokia Care Point.
Warning: This reset code will delete all data from the phones memory.
Nov 05, 2009 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 will not turn on. It only vibrates.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
