Question about Dell Inspiron 6000 Notebook
My dvd r/rw drive does not work. it sounds like it is reading cds and dvds but nothing happens.
  • 79 Answers
Try to boot from some bootable cd/dvd (eg. windows cd) to check if it isn't software problem, if it won't boot, try to clean laser lens using small paintbrush and little alcohol. If it is only software problem, go to control panel > system > device manager and uninstall all cd drives and restart computer
Posted on Jul 11, 2009
2 Suggested Answers
otacon
  • 1950 Answers
SOURCE: CD-RW/dvd drive can't read any cd/dvds
Which model VAIO do you have?
Posted on Dec 31, 2007
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
Can operate with CD ROM's. Won't recognize DVD's.
Sounds like the drive could be going bad. The way the laser reads DVDs vs. CDs is different, that is why you are able to read one, not the other. I had this happen to me, except the opposite. It could read DVDs, not CDs. Had to buy a new one, and all is well.
Apr 22, 2009 | Pacific Digital Mach 16x8x16x Double-Layer...
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
He cant read DVDs
Is the optical drive a DVD-ROM or just a CD or CD-RW drive?
Mar 18, 2009 | Computers & Internet
My Lite-On combo sohc-5236v does not read CD but it reads DVD.
The reason for this is most likely Copyright protection. If this is the case, it will read DVDs as it is only a DVD-ROM, but what happens in the case of CDs, is that they recognise the drive as a Burner, and the Copyright that is embedded into the CD wont let the drive read it. This also happens with DVDs in some DVD burners.
The way to test this, is by getting a CD-RW disc that has music or files on it, put it in the drive, and see if it reads it. If it doesn't, then you may have a fault with the drive, but if it does read the CD-RW, then the only way round it that I know of, is to buy a CD-ROM drive and use both drives.
Dec 05, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Problem burnind and reading!
Check that the writable DVDs you are using are compatible (+/-) with your LG DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your LG CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 21, 2008 | LG GSA-4082BI DVD±RW Burner
PIONEER DVD-RW DVR-112D problem
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
DVD player won't read most DVDs
Its faulty... without doubt... these "Combo" drives are often real flakey... sorry about that the laser diode has probably burnt out...
Jul 03, 2007 | Plextor PX-708UF DVD±RW Burner
Cannot read dvds
sounds like your dvd laser has failed if it reads other media as there are normaly 2 lasers one for reading cds and one for dvds try using a cleaning disc to clean the lenses
May 27, 2006 | NEC ND-6500A DVD±RW Dual Layer Burner
Dell Inspiron 6000 Notebook Logo
Clive
Clive
Alun Cox
