To Whom It May Concern: On June 18, 2009 I purchased a copy of the Recover Data for Linux - Home User License, Item# Recover Data for Linux(Linux) for $45.00 USD, by Recover Data Tools, to try to recover a Compaq Wide SCSI Hard Disk, Product AA03631AC6 and Revision 3A06, which was my 5th hard disk in my desktop system. I am currently using the Mandriva Linux 2008 Spring Operating System. My system consists of an AOpen AX4B-533 motherboard with an Intel(R) Pentium(R) 4 CPU 2.40GHz (100x17.0) with a Phoenix/Award BIOS Version R1.11 03/13/2003-i845E-W83627-6A69VABHC-00, 2Gigs DDR RAM, Radeon 9250 with 256 Megs VRAM, ADM983 Linksys EtherFast 10/100 PCI card, QLogic C21 Dual Ports Ultra 2 SCSI PC2010403-09 Host Adapter ‎ISP1020 Fast-wide SCSI Card with SCSI BIOS Version 6.26, and the connected SCSI devices are as follows: Identification Vendor: IBM Description: ‎IC35L018UWD210-0 Disk identifier: ‎IBM IC35L018UWD210-0 Media class: ‎hd Bus identification Vendor ID: ‎0x0000 Device ID: ‎0x0000 Sub vendor ID: ‎0x0000 Sub device ID: ‎0x0000 Connection Bus: ‎SCSI Channel: ‎0 Logical unit number: ‎0 Device Old device file: ‎/dev/sda Partitions Primary partitions: ‎1 (sda4) Extended partitions: ‎2 (sda5, sda6) Misc Geometry: ‎2231/255/63 (CHS) Disk controller: ‎0 Module: ‎qla1280 Identification Vendor: ‎COMPAQ Description: ‎DCHS09U Disk identifier: ‎COMPAQ DCHS09U Media class: ‎hd Bus identification Vendor ID: ‎0x0000 Device ID: ‎0x0001 Sub vendor ID: ‎0x0000 Sub device ID: ‎0x0000 Connection Bus: ‎SCSI Channel: ‎0 Logical unit number: ‎0 Device Old device file: ‎/dev/sdb Partitions Primary partitions: ‎1 (sdb4) Extended partitions: ‎1 (sdb5) Misc Geometry: ‎1107/255/63 (CHS) Disk controller: ‎0 Module: ‎qla1280 Identification Vendor: ‎IBM Description: ‎DCAS-32160W Disk identifier: ‎IBM DCAS-32160W Media class: ‎hd Bus identification Vendor ID: ‎0x0000 Device ID: ‎0x0002 Sub vendor ID: ‎0x0000 Sub device ID: ‎0x0000 Connection Bus: ‎SCSI Channel: ‎0 Logical unit number: ‎0 Device Old device file: ‎/dev/sdc Partitions Primary partitions: ‎2 (sdc1, sdc2) Misc Geometry: ‎263/255/63 (CHS) Disk controller: ‎0 Module: ‎qla1280 Identification Vendor: ‎IBM Description: ‎DNES-309170W Disk identifier: ‎IBM DNES-309170W Media class: ‎hd Bus identification Vendor ID: ‎0x0000 Device ID: ‎0x0003 Sub vendor ID: ‎0x0000 Sub device ID: ‎0x0000 Connection Bus: ‎SCSI Channel: ‎0 Logical unit number: ‎0 Device Old device file: ‎/dev/sdd Partitions Primary partitions: ‎2 (sdd2, sdd3) Extended partitions: ‎2 (sdd5, sdd6) Misc Geometry: ‎1115/255/63 (CHS) Disk controller: ‎0 Module: ‎qla1280 and a TOSHIBA CD-ROM XM-3401TA SCSI CDROM drive, a Cypress Semiconductor Corp. USB-2.0 IDE Adapter to NEC DVD_RW ND-3550A drive, an Iomega Model: ‎ZIP 100 ATAPI disk drive and a Teac 1.44M 3.5 inch floppy disk drive. However, I seem to lost my 5th hard disk, which I have all my files on and Mandriva Linux 2008 Spring OS. I have been running AutoCAD Release 13 for Windows through WINE on this hard disk and I am not sure if it overwrote something on this hard disk to make the file system not be recognize any more. This is the first time I had a problem like this with Linux. The hard disk runs and shows up on the POST QLogic QLA1020X SCSI device scan list and if I go into the QLogic Fast!Util SCSI Version 1.33, firmware based hard disk diagnostics, I can run the Verify Media Test for bad blocks, which will continue through the whole hard disk without detecting any bad blocks. The total number of blocks for this hard disk is: 43D635F. However, I have downloaded your Recover Data for Linux Platform software and installed it with the license key code but the program doesn't find the hard disk. Normally this hard disk would be designated as /dev/sde hard disk device under Linux but now it's undetected and won't show up. However, Partition Magic 8.0 finds it under DR-DOS 7.03 and show all the partitions on that hard disk as being in tack even though it doesn't fully support Linux's ext3 partitions to fix any problems it finds. So the data on this hard disk must be still in tacked. How can I restore the hard disk to access it and preferably without costing a lot of money? Please email me back ASAP! Thank you, David A. Smith
  • 4 more comments
  • davidasmith0 Jul 11, 2009
    No, I haven't tried booting Sprinrite. Will it work with Linux ext3 partitions? Does it require Microsoft Windows? Where can I purchase an image to download and burn to either a CD or DVD? I have sent email to Data Recovery Support but no response and they claim to have 24/7 support.
    Thank you,
    David
  • davidasmith0 Jul 12, 2009
    My email address is: DavidASmith072@electronicaidesdesign.com
    This is very kind of you to do this and I sure appreciate it. I will let you know how it works.
    Thank you again for your help,
    David
  • davidasmith0 Jul 13, 2009
    Dear Raymond,
    Thanks for emailing me the Sprinrite.iso image file. I have tried
    burning it to a CD-RW but it doesn't boot. In fact, the .iso file seems
    very small, like 1.5 Megabytes in size. I used K3B to burn the
    Spinrite.iso and I sent you a reply email with the attached log file result from the K3B program.
    Thank you,
    David
  • davidasmith0 Jul 18, 2009
    Yes, Raymond sent me two CDs, which came yesterday afternoon and I successfully made a bootable
    SpinRite 6.0 CD and ran it and it found my 5th SCSI hard disk with it's
    all partitions in tack. I first ran the level 2 recovery check and it
    didn't find any errors. So then I ran the level 3 test over night and
    it found a couple of errors that it recovered and fixed. However, when
    I boot Mandriva Linux 2008.1 from my 1st hard disk, I still can't
    access the 5th hard disk with neither Gparted, fdisk or the Mandriva
    Manage disk partitions from within the Mandriva Linux Control Center
    2008.1. That 5th hard disk doesn't show up anywhere. I even did:
    # cd /dev/disk/by-uuid
    # ls -la
    total 0
    drwxr-xr-x 2 root root 280 2009-07-18 13:33 ./
    drwxr-xr-x 6 root root 120 2009-07-18 07:31 ../
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 0204b731-659d-4000-a164-7bc503473425 -> ../../sda6
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 12F8-1556 -> ../../sda4
    lrwxrwxrwx 1 root root 10 2009-07-18 13:32 1384ebd2-9656-11d9-97f0-79edab215a7a -> ../../sdd5
    lrwxrwxrwx 1 root root 10 2009-07-18 11:31 2076-DF3A -> ../../sdj2
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 2EE84C5FE84C2803 -> ../../sdc1
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 3E93-43AF -> ../../sdb4
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 42a57776-79aa-11d2-9620-e6a4ed5e25f9 -> ../../sdc2
    lrwxrwxrwx 1 root root 10 2009-07-18 13:33 48BF-4F70 -> ../../sdi5
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 60733da1-c141-4207-aded-c07914d480d4 -> ../../sdb5
    lrwxrwxrwx 1 root root 10 2009-07-18 11:31 7b2cec2c-f572-4a15-8a60-c66122354257 -> ../../sdi1
    lrwxrwxrwx 1 root root 10 2009-07-18 07:31 819bd2fc-3fc8-4949-96f0-8c9efadbd883 -> ../../sda5
    lrwxrwxrwx 1 root root 10 2009-07-18 13:32 f80c9fc2-85b2-11d7-86b6-00001c002b55 -> ../../sdd2
    #l
    By the way, where is the manual for SpinRite 6.0 on the CD? I only see
    a strange file on the CD that is supposed to have the manual on it,
    which is named: SpinRite v6.3431119 Retail.rar, which I can't read in
    Linux.
    Thank you,
    David
  • davidasmith0 Jul 19, 2009
    It's Mandriva Linux 2008.1 Power Pack.
    David
  • davidasmith0 Jul 22, 2009
    I would like to thank Raymond and Tim for their solutions to my 5th hard disk access problem. It was $15 well spent to get a solution so fast.
    Thanks guys,
    David A. Smith
    President:
  • 2,777 Answers
Hello there, David, did Raymond ever get you taken care of? I would be very careful since it sounds like he may have emailed you pirated / stolen software. There has never been a free version of spinrite so for him to email it to you is not legal.
There may be a trial version of the software out there, but that will not accomplish what it is you are trying to do. It sounds like the file system header information on the drive has become corrupted. You say that linux isn't even seeing the device at all? When you go to a terminal, go to /dev/disk/by-uuid, do a ls -la in the directory, does it not see the drive here? It definitely should.
Is the device still listed in your fstab?
Thanks
Tim
Posted on Jul 13, 2009
  • Tim Grayson
    Tim Grayson Jul 19, 2009
    Hello there, you can open that rar file in linux using a utility called "unrar", not sure what distribution you are using of linux, if you tell me I can tell you how to install it. You have a ton of disks on the system, are you sure it's not one of the recognized ones under dev?
    Thanks, let me know
    Tim
  • Tim Grayson
    Not sure if my comments are getting through, comment system is acting up, watching for your reply
  • 4,924 Answers
My advise is to go online at linux and get a version of the operating system ...for free ( just download it )
look for the version that is able to boot a system from the CD (bootable version ) You will find it probably as an Image file ...I dontknow exactly ...what I know for sure is that there are availableversions that will allow you to use linux directly from a cd...if Imade myself clear....after you had acces on your files just back 'em up...or copy them on another hard disk ( external) until you reinstalland verify to see what exactly went wrong ....this is the cheapersolution you will ever get ...infact I bet it will cost you just ablank cd ..and the future power bill ...Good luck !
http://linux.hangar.ro/linux-cd/slax
ps this is a small linux that will work from cd ..(ISO file )
Posted on Jul 12, 2009
  • 331 Answers
Thats quite some novel..... have you tried to boot to spinrite cd and recover from there
Posted on Jul 11, 2009
  • Raymond Ramirez
    Raymond Ramirez Jul 11, 2009
    I have the disk image make your computer boot to cd the image is a linux boot.
    let me have your email and I will email it to you
  • Raymond Ramirez
    Raymond Ramirez Jul 12, 2009
    you should have got it. let me know
Linux Data Recovery Issues.
Hi Rosu,
I have this site for you in order for you to reformat your PC including image. Hope it helps.
How to recover partitions and data using Linux Tutorial
May 02, 2014 | Computers & Internet
How to Recover accidentally deleted data from formatted Linux partitions.
You can also try to use a very effective and affordable application for Linux Data Recovery from here:- Linux Data Recovery
Apr 18, 2014 | Computers & Internet
Map data not found but it is there from the amount of memory taken up
It's likely that your map (data) got corrupted. You can recover by restoring your back-up copy of the map (that you'd previously done via TomTom HOME on your computer).
If you don't have a back-up copy, try using your computer's disk check utility to fix the file system and recover data (from the storage media on your GPS device). Just connect the GPS to your computer, no need to use TomTom HOME, just use the Properties tab and use the Tools to run a disk check (assuming you're using Windows).
If that doesn't work, you may want to purchase & download and install the latest copy of the map from the TomTom website (via HOME).
Aug 24, 2013 | Tomtom GO 300 GPS Receiver
Restore
These HPs typically have a partition permitting restoration to a condition of the factory defaults via F10 on rebooting the computer. I would certainly have tried system restore before any destruction return to factory defaults. If you can boot the computer from a USB stick (changing the boot sequence via F1 setup), and have it load in a Linux OS, you can recover some of your data files. PC User June 2011 offered such on its disc. Doubtlessly, an update of the technique is elsewhere available. You will want to update service packs after a restore, very likely.
Sep 09, 2011 | AMD Hewlett Packard Pavilion m8000n PC...
Forgot my password top log in
you cannot login to the computer. to recover data use a linux live cd and copy data into an external hard disk.
Feb 28, 2011 | Computers & Internet
Hello every one, how can i recover my data from an inaccessible user account because of registry information was changed. pls those datas mean every thing for me
Just boot from a Linux Live-CD like http://www.knoppix.net/ and use it to cut/paste all your files from that dead user account in another one. But you should also copy them on an external hard disk as a backup - it's very likely that the corruption will grow and the entire Windows will be eventually affected.
Jan 11, 2011 | Computers & Internet
How do you do system recovery for linux?
try the ubuntu site. there should be a fix there in the forums
also I found this list on tech republic:
1: Knoppix
[UPDATE: New link] Knoppix is one of the better tools for rescuing data from sick machines. It’s a full-blown live Linux distribution with a strong, user-friendly GUI that will allow you to easily mount a drive and then copy the data (which you will locate in an easy-to-use file manager) to an external source. Of course, Knoppix comes with the full arsenal of Linux commands, which place just about everything you need at your fingertips.
2: Trinity Rescue Kit
Trinity Rescue Kit might leave you wondering, “Why isn’t this tool being developed faster and on a larger scale? Although TRK is rather slow to develop, what it offers is just short of amazing. Place it on a USB drive, boot your virus-laden machine, and scan the mounted drives with clamav, antivir, bitdefender, and more. This tool is all command line, so you might have to bone up on your commands to really make use of it.
3: Avira AntiVir
Avira AntiVir is a command-line antivirus tool that is fast, robust, and dependable. There is a GUI tool, but installing it is almost more trouble than it’s worth. (It requires Java.) Installing AntiVir on Linux isn’t the easiest of tasks, but it’s certainly no kernel compilation.
4: GParted Live
GParted Live is a live Linux distribution that allows you to manipulate partitions on a drive. It supports numerous file systems and lets you can resize, create, and delete, partitions. You can run GParted Live from a CD or a USB drive, so it’s very portable.
5: SystemRescueCd
SystemRescueCd is another live Linux rescue CD that offers numerous tools to handle numerous tasks, including partition manipulation, file recovery, hard disk testing, ftp, and disk formatting. As with most live Linux distributions, you can place SystemRescueCd on either or CD or USB drive, and it offers an easy-to-use GUI and plenty of tools.
6: Ubuntu Rescue Remix
Ubuntu Rescue Remix is quickly becoming one of my favorite data recovery tools. Like all good live Linux CD tools, it includes an outstanding GUI (it is Ubuntu after all) that can help you handle tasks other tools can’t handle. You can recover and rescue Mac files/filesystems, recover data from nonstandard external drives, recover deleted files, and more. The one thing URR is missing is antivirus tools. But, since this is a Linux rescue disc, once installed, you can simply add the tools you need to your USB live CD.
7: F-Secure Rescue CD
F-Secure Rescue CD is based on Knoppix and allows you to check the integrity of your installed applications. It also allows advanced data repair and recovery, as well as recovery from that ever-dreaded malware!
8: Ddrescue
Ddrescue is a Linux tool designed to copy data from one file block device to another. This tool will aid you in rescuing data when your drive is suffering from read errors. Unlike many of the tools on this list, Ddrescue is not a live distribution but a tool you will use on a running Linux machine. So to rescue data, you will have to attach that troubled disk to the working Linux machine.
9: Safecopy
Safecopy is similar to ddrescue, allowing you to copy files from a disk suffering from I/O errors. It also includes a tool that allows you to read data from CDs in raw mode, as well as issue device resets and simulate bad media for testing and benchmarking.
10: Linux rescue mode
This is the only entry on the list that isn’t a downloadable tool. Linux rescue mode is a mode booted with the help of a Linux boot CD, allowing you to repair a broken system. From rescue mode, you can recover a root password, repair or reinstall the boot loader, and more. When you boot into rescue mode, it will typically mount your installed system into /mnt/sysimage, where you can take care of any business necessary.
More rescue tools?
These 10 Linux tools can help you recover, rescue, and repair a Linux, Windows, or Mac machine. Of course, plenty more tools are out there. Have you come across a Linux tool that can help you repair or recover a damaged or sick drive? If so, share it with your fellow TechRepublic members.
Apr 26, 2010 | Belkin (F5D5231-4) Router
What is the product key for word home and student 2007
The product key was shipped to you originally with your purchased product. Sharing keys is against the Microsoft End-User License Agreement (EULA). Please use your license key. If you cannot locate your key, you will need to purchase a new copy of Office.
Jan 03, 2010 | Microsoft Office Professional 2007 Full...
What is the difference between linux operating system and windows?
major difference between them are
  1. Reduces the risk of carpal tunnel syndrome
  2. When linux is properly installed, there no longer a need to use the mouse. Chances of you using a mouse is close to zero.
  3. Use the extra cash for rewards
  4. Linux is 100% free while Windows Vista Ultimate costs $398.99 at the time of writing. Companies that pay a licensing annually could have used the money for other things like buying an additional server to reduce the load or even give a bigger bonus to its loyal employees.
  5. Formats are free, freedom is preserved
  6. Linux file formats can be accessed in a variety of ways because they are free. Windows on the other hand makes you lock your own data in secret formats that can only be accessed with tools leased to you at the vendor’s price. “What we will get with Microsoft is a three-year lease on a health record we need to keep for 100 years”
  7. Zero risk in violating license agreements
  8. Linux is open source so you are unlikely to violate any license agreement. All the software is happily yours. With MS Windows you likely already violate all kinds of licenses and you could be pronounced a computer pirate if only a smart lawyer was after you. The worldwide PC software piracy rate for 2004 is at 35%. Which means that 3 out of 10 people are likely to get into real trouble.
  9. Transparent vs Proprietary
  10. MS Windows is based on DOS, Linux is based on UNIX. MS Windows Graphical User Interface (GUI) is based on Microsoft-own marketing-driven specifications. Linux GUI is based on industry-standard network-transparent X-Windows.
  11. Better network, processing capabilities
  12. Linux beats Windows hands down on network features, as a development platform, in data processing capabilities, and as a scientific workstation. MS Windows desktop has a more polished appearance, simple general business applications, and many more games for kids (less intellectual games compared to linux’s).
  13. Customizable
  14. Linux is customizable in a way that Windows is not. For example, NASlite is a version of Linux that runs off a single floppy disk and converts an old computer into a file server. This ultra small edition of Linux is capable of networking, file sharing and being a web server.
  15. Flexibility
  16. Windows must boot from a primary partition. Linux can boot from either a primary partition or a logical partition inside an extended partition. Windows must boot from the first hard disk. Linux can boot from any hard disk in the computer.
  17. Mobility
  18. Windows allows programs to store user information (files and settings) anywhere. This makes it impossibly hard to backup user data files and settings and to switch to a new computer. In contrast, Linux stores all user data in the home directory making it much easier to migrate from an old computer to a new one. If home directories are segregated in their own partition, you can even upgrade from one version of Linux to another without having to migrate user data and settings.
  19. Proven Security
  20. Why isn’t Linux affected by viruses? Simply because its code has been open source for more than a decade, tested by people all around the world, and not by a single development team like in the case of Windows. This leads to a lightning fast finding and fixing for exploitable holes in Linux. So that my friends, proves Linux as having an extremely enhanced security and lesser chances of exploits compared to Windows.
Apr 25, 2009 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
Alun Cox
k24674
