Question about Dell Optiplex 755 Minitower Desktop Computer
Optiplex 755 flashing orange power button light only
Only light otherwise is the green led on the network card. No fans, optical drive or anything else powers up.
    Scholar:
  • 113 Answers
Sounds like you only have power going to your motherboard.
The power supply might be bad on it, that or maybe the power cord is going bad and is only letting a small amount go through. I don't see why there should be a problem if you have even a little bit of power going though.
Posted on Jul 11, 2009
My dell optiplex 755 showing orange colour light on power butten
Posted on May 23, 2010
SOURCE:
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
OptiPlex 755 flashing orange light only
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Aug 27, 2012 | Dell Computers & Internet
Sounds demanding. I would like this solution sounds better. Capish?
http://support.dell.com/support/edocs/systems/op755/en/UG/HTML/trouble.htm#wp1303994
Bad Power Supply -> Replace
(Also FOLLOW Anti-Static Precautions, and to include clean out the inside of the computer)
Regards,
joecoolvette
Aug 27, 2012 | Dell Optiplex 755 Minitower Desktop...
Optiplex 755 showing orange colour light on power button.. how can i fix this problem
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 24, 2012 | Dell Optiplex 755 Minitower Desktop...
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I got a dell optiplex 755 base unit from work as they were throwing them out but I cannot get a picture on 2 different monitors,no beeps no bios nothing.I connected a key board and mouse (both usb).Unit...
I recently worked with a couple of used Dell desktops that someone got from work. Sound familiar? I couldn't get them to come on because the plastic bracket that holds down the CPU heatsink was broken. The heatsink was also covered with a carpet of dust. The new owner could've bought a new heatsink/bracket online, but they declined to spend money. Open it up, make sure everything is in order to diagnose the problem.
Aug 15, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Hi,when I try switching my dell on it runs but the power led is Orange and it doesn't do anything
having this problem may be caused by you hard drive or video card. those two may be not fit in to its place, kindly check the cords of it is perfectly fit or placed.
Jul 03, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 13, 2011 | Dell Inspiron 518 Desktop Computer
My Dell inspiron 518 will not turn on when power button is pressed. Green LED on back of power supply lights and orange LED on motherboard turn on. No fan operation on anything. Thinking it is the switch...
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
Feb 14, 2011 | Dell Inspiron 518 Desktop Computer
Dell Optiplex 755 Minitower Desktop Computer  Logo
6,351 people viewed this question
Clive
Clive
Alun Cox
