Hello my name is Heath it will be my pleasure to assist you. If there is a spot where you add and check the oil it doesn't need mix if it doesn't then you will need to mix the gas.
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
Blades have proved to be the main wearing parts. However, they do have a good life expectancy. Blades are made from special material, hardened and heat-treated to a standard which results in a blade that is hard but not brittle.
