Canon imagePROGRAF  iPF8000 Printer Logo
R
Ronnie Ramirez Posted on Jul 03, 2015
Print head error - Canon imagePROGRAF iPF8000 Printer
basilis
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 16, 2017
basilis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
21817
Points
8
I have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- [email protected] for questions and support
I Have a Sawgrass GS 1000 Printers Showing error sc 282-13 what could be the problem and how can I solve it..
Error SC 282-13 on a Sawgrass GS 1000 printer typically indicates that the printer is experiencing a problem with the print head assembly. Possible causes of this error include:
  1. A problem with the print head: The print head may be damaged or malfunctioning, causing the error to occur. If the print head is damaged, it will need to be replaced. If it is simply malfunctioning, cleaning the print head may resolve the issue. To clean the print head, follow the manufacturer's instructions for your specific printer model. This may involve using a cleaning solution or simply running water over the print head.
  2. A problem with the print head cable: The cable that connects the print head to the printer may be damaged or not securely connected, causing the error to occur. If the cable is damaged, it will need to be replaced. If it is simply not securely connected, make sure that it is properly plugged in on both ends.
  3. A problem with the print head alignment: The print head may not be properly aligned, causing the error to occur. If the print head is not aligned correctly, the printer may not be able to print properly. To fix this issue, follow the manufacturer's instructions for aligning the print head. This may involve using the printer's built-in alignment tool or manually adjusting the print head position.
If the error persists after trying these steps, it is recommended to contact Sawgrass customer support for further assistance. They may be able to provide additional troubleshooting steps or arrange for service if necessary.
2answers
Canon ipf825 error 03800500-2f2f
Code: 03800500-2F2F · Description: Head management sensor error. The head management sensor detected a ink discharge error. A sensor sensitivity error was ...
5answers
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Oce colorwave 300 error code 22014
The print head temperature control does not work. Turn off the printer, and unplug. Replug and start up printer. If problem persists, turn off printer again. Remove all print heads. Close up covers on carriage and top cover for printheads. Restart printer. Printer will ask that heads be reinstalled. Start with head 1 and progress one at a time. If error comes on, it will be the last print head that is causing the error. Replace that print head and continue inserting print heads one at a time until there are no errors.
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
1helpful
2answers
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
2answers
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
2helpful
2answers
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
old marine
old marine
ZJ Limited
ZJ Limited
