Question about Golden Technologies Avenger 4 Wheel Electric Scooter
The battery takes a charge, but will not power scooter
Cosco ability care essentials 4 Wheel Mobility Scooter, similar to the Golden Technologies Avenger 4 Wheel Electric scooter.
The battery takes a charge, even got a new one, but the only thing that works is the horn, and just barely. The scooter won't move at all. I tried tightening all the electrical connections but still got the same result. Any Ideas?
Thanks
  • 1 more comment
  • keh600 May 11, 2010
    My Golden Avenger Scooter hesitates almost to a stop then starts up and then hesitates. I have replaced the betteries and it still does this...any ideas ??? Thanks
  • Anonymous Mar 13, 2014
    All motor functions work as should, changed in line horn fuse, that now works, all other electrics, hazards, lights and indicators not working.
  • Anonymous Mar 29, 2014
    wiring diagram for a lark 4 wheel mobility scooter which has 4 x 12v batteries and where I can get a new circuit board?
  • 175 Answers
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 53 Answers
Normally the motor brushes but i don't think you can change them
try connecting the motor directly to the batteries to eliminate all other parts if same problem change the motor (if you can get one)
Posted on May 21, 2010
Chair wont charge lights not comeing on but still has 1/2 power according to lights
depending on age of unit batteries can get bad just like in a car and won't charge. auto parts store can check batteries for you, or garage
Nov 21, 2014 | Golden Technologies Avenger 4 Wheel...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
It won't move when battery is fully charged
only guessing but today I fixed one with this problem by spraying the speed potand connectors under the top with radioshack contact cleaner/lubricant.now scooter runs fine .
Dec 26, 2013 | Cosco Juvenile Cosco Ability Care 4 Wheel...
My cosco scooter is showing fully charged all green but when I push the foward it will not move and the light is flashing
try taking the top off steering and spraying the speed pot and all connecters with contact cleaner/lubricant from Radioshack.I did this today and now the cosco scooter runs real well.
Nov 16, 2012 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Need a new battery
it probably takes 2. we just got some from www.baterysharks.com
Sep 02, 2012 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Won't move lite on battery fully charged
I had this problem with the Cosco 4 wheel scooter. It turned out that one of the primary power lines under the shroud (back housing cover) was loose. It was not disconnected -- just loose. Apparently the loose connection would support enough current flow for the diagnostic circuit, but not enough to move the scooter (similar to using too small of a wire gauge in its effect). Once the power cable connector was tightened down so that the cable would not rotate on the connector, everything worked correctly.
The same symptoms could also be caused by a faulty power cable. If you have access to a multimeter, test the resistance along each cable path. If a path has an unusually high resistance, compared to the others, start to look for problems there.
Apr 16, 2010 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Golden Technologies Avenger Bateery Problem
Battery needs replacing when that happens.;
Regards; Aaron
Aug 27, 2008 | Golden Technologies Avenger 3 Wheel...
Golden Technologies Avenger 4 Wheel Electric Scooter Logo
772 people viewed this question
Top Golden Technologies Health & Beauty Experts
Rob Hill
Rob Hill
Colin Taylor
Marvin
Marvin
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
