Question about kawasaki Full Suspension Mountain Bike Men
My 2000 kx 250 will not reach its pwerband in the first three gears. It remains the same or bogs down whats the problem?
    Problem Solver:
  • 17 Answers
Might be the wrong jetting, or possibly spark plug gap is not correct.
Posted on Aug 11, 2009
2001 KX 250 transmission oil capacity
Hi, Mkenne7 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://thumpertalk.com/forums/topic/787559-2002-kx250-gear-oil How to change gear oil in 2 stroke dirtbike KX 250
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
OEM Parts for Kawasaki
2001 Kawasaki KX250 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 04, 2012 | 2003 kawasaki KX 250
1999 Kawasaki KX 250 how to overhaul the transmission
Hi, Waynepurcell for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Help Transmission Rebuild Question
KX250 Geared 2 Stroke series Part 16 Gearbox reassembly https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
1999 Kawasaki KX250 Owner Manual
Apr 15, 2012 | kawasaki Motorcycles
2005 Kawasaki KX 250 bogs out
Hi, Anonymous engine "BOG" is mainly caused by a rich air and lean fuel condition but it can also be caused by a lean air and rich fuel condition this situation rarely occurs and is only caused by the misinformed weekend warrior that owns a toolbox. If the bike has been sitting for months or years you will have to completely disassemble the carburetor and submerge the parts (except rubber parts) in "Carburetor Dip" It usually comes in a gallon bucket with a wire mesh basket that can be purchased at any automotive store. If it is not the above scenario then the following explanation will apply.
The more you open your throttle the more vacuum you are creating in your carburetor venturi and your intake manifold. When you are operating at higher RPM any unmetered air that leaks into your system can become more obvious.
Unmetered air is air that is getting into your system after the fuel has been delivered. If you have unmetered air getting into your system between the butterfly/slide of the carburetor and the cylinder head this will create a lean condition.
All of the rubber components of the fuel system like vacuum hoses and intake manifold that you mount the carburetor to are made of rubber. If none of these components have been changed they are more than likely highly degraded and probably cracked in places to allow unwanted-unmetered-contaminated air into the combustion chamber. Check all of your vacuum lines and vacuum plugs for carburetor synchronization. The vacuum plugs are in the head just after the rubber intake manifolds. The petcock has a vacuum line as well as part of the emission system.
1. Check the intake manifold for fissures.
2. Ensure the bands used to tighten the manifolds down on the intake are secure and have not bound up the manifold.
3. Make sure air box fittings are not warped and fit completely over the carburetor.
4. For 2 strokes make sure the power valve is adjusted properly.
Your airbox is metering air and is the first step in a process of consuming air and fuel. The system requires the resistance of the air filter in order to get the proper vacuum to "SUCK" the fuel out of the float bowl and create the proper venturi effect.
Improper mounting and sealing of the airbox will create a small lean effect. This might seem like no big deal but you are inviting dust and debris in your engine that is doing slow damage by not having proper fitment. Fix it so you know it's not contributing to your issue. Pick the low-hanging fruit first.
Do not go and start adjusting anything at this point. It ran fine before. There is something wrong with the assembly or a component. Do not adjust your floats. Get it back to where it was. The moment you start tweaking everything is the moment you lose OEM settings which are a must-have for fine-tuning and maximum performance.
Fine-tuning your carburetor and multi carb syncing come at the very end following the proper procedure established by the Carburetor Gods.
kx250 bogging problem
KX250 Bogging out
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX-125-KX250-Service-Manual-2003-2004-2005-2006-2007-2008.pdf
2005 Kawasaki KX250 Owner Manual
Mar 22, 2012 | 2005 kawasaki KX 250
2001 Kawasaki KX 250 gear oil capacity
Hi, Chrisncourtn for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Sep 13, 2010 | 2003 kawasaki KX 250
Whats the shif pattern for a 2003 kx 250
what do you mean the gears the gears go as get back to me
6
5
up
down
Sep 20, 2009 | 2003 kawasaki KX 250
HOW DO I SHIFT A 2003 KX 250
pull your clutch in on the left handlebar push the shifter lever down and let you clutch out slowly while giveing the bike a lil bit of gas. But if you don't know how to ride i wouldn't be jumping on a kx 250
I have a 1996 kx 250 that will not select 4th gear going up or down the gearbox but selects other gears fine what could be the problem
Selecter forks could be damaged, gear shift shaft bent, return spring faulty, clutch dragging maybe! Try rocking it backwards and forwards engine off and see if you can find that gear! Good Luck - The Yeti
May 13, 2009 | kawasaki KX 250 Motorcycles
1994 yz 250 bogs down
Have you cleaned the carburator ? It seems the main jet has some kind of obstruction.
Try cleaning the carburator and well a tune up would be fine too after the clean , check the plug/s & air filter too.
May 09, 2009 | 2000 Alfer VR 2000 Enduro
Gear change
it probably needs a clutch adjustment. try rocking it hard up,down side to side while changing gears. some peopl ecall it transmission lock.
Mar 17, 2009 | 2003 kawasaki KX 250
QUAD QUESTION! 1998 yamaha warrior 350 bogging down
sounds like fuel starvation
do you have a petcock plugging or a dirty carb?
pull the fuel line and check flow
Nov 17, 2008 | 2003 Yamaha YZ 250 F
kawasaki Full Suspension Mountain Bike Men Logo
127 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Marvin
Marvin
obsteiner
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
