Cars & Trucks Logo
A
Anonymous Posted on Jul 03, 2015
Necesito el diagrama del cicuito electrico de un motor isuzu 4jg2, del 2004, de una isuzu Bighorn, donde lo puedo conseguir
_-__-___-_
Level 3:
  • Isuzu Master 20,706 Answers
  • Posted on Jul 03, 2015
_-__-___-_
Isuzu Master
Level 3:
Answers
20706
Questions
Helped
6803227
Points
57965
Spanish on English forum? really?
I need circuit electrical diagram of a 4JG2 Isuzu engine, 2004, an Isuzu Bighorn , where I can get it.
what country? we cant guess that, and i guess you dont know engines ,EFI , spark and many parts are all different by that fact.
if the USA car on this USA forum is a 4JG2
then all this is found at alldata.com
it a diesel engine, and we dont have them here.
it is direct injected diesel. sold in most markets, but not here.
Our isuzu dealers are gone now, they left uSA. for passenger cars.
so cant go there.
then go to yours and ask them?
"In 2002, the Trooper was discontinued in the United States."
so now i know car is not a USA car. and that our books dont cover cars not sold here.
so why not ask Isuzu this, go to the dealer buy the FSM book.
or join any non USA forum for isuzu. trucks. troopers
try here, link is random
http://forum.planetisuzoo.com/viewtopic.php?t=16663
they speak english only there too.
i dont see any spanish speaking isuzu forums.
best wishes.
  • 1 more comment
  • _-__-___-_
    _-__-___-_ Jul 04, 2015
    go to our dealer, walk up to the parts counter, and say,Senior;' can I have the oem factory service manual for my car with this xxxx diesel option
    only that works,100% of time, but never here, ours or GONE.
  • Anonymous Jul 04, 2015
    watch out some have manuals called engine supplements and wiring,.. ask... wins.
    post country maybe someone in your country can see your spanish question and might even have the correct book? but id bet not.
Necesito el diagrama de relevadores del motor fors escort 2.0 litros del 97
el diagrama lo puedes conseguir en algun taller mecanico que tenga ondeman 5 programa michelle como dato es una caja completa se encuentra debajo del filtro de aire parece una computadora pero no lo es si quieres puedes abrirla y empezar a descubrir el sistema espero te sirva el dato.
18helpful
2answers
DIAGRAMA DE SINCRONIZACION DE CADENA DE TIEMPO NISSAN ALTIMA 94 2.4
tengo el problema con mi nissan sentra 1.6lt 99 sele safo un tornillo del pinon q sostiene las dos cadenas i no puedo ponerlo asi nomas tengo q vajar el motor para eso
12helpful
2answers
Trobleshooting p0073 DIFINICION CIRCUITI ALTO DEL SENSOR DE TEMPERATURA DEL AIRE AMBIENTE AAT EXPLICACION El modulo de control electronico ecm a detectado una condicion de alto voltage en el circuito...
El código P0073 es descrito como el sensor de temperatura del aire ambiente del circuito de entrada de alto. Que consiste en el circuito del sensor de temperatura del aire exterior.
El sensor esta instalado frente al radiador, detrás de la rejilla. Probablemente el problema es que el sensor ha fallado o que el cableado presente algun corto en el mismo o cables deshilachados. Inspeccione los cables y conectores que lleva a la sonda. También puede hacer referencia a un manual de reparaciones de Jeep Liberty para obtener información específica, pero también se puede utilizar un multímetro digital (medidor digital ohmios voltios) para verificar la ohmios del sensor.
Espero que esto sea de ayuda (recuerde calificar esta respuesta). Buena suerte.
39helpful
2answers
COMO CAMBIO UNA CADENA DE TIEMPO Y DONDE ENCUETRO LOS DIAGRAMAS
tengo un mazda mpv le cambie los baleros no le podia quitar el sensor y quise quitar la polea de la del motor y se movi el tiempo como puedo ponelo vien o conseguir un diagrama
1helpful
Cuantos litros de aceite y que tipo de aceite lleva una jeep patriot 2008 4 cilindros gasolina y donde se encuentra su filtro de aceite y gasolina
hola que tal el filtro de gasolina lo traen arriba de una tolva que se encuentra exactamente por las ruedas delanteras ( abajo del motor) quitas esa tolva y es de lo mas facil cambiar el filtro y el aceite,, el de gasolina si esta un poco mas complicado pues esta dentro del tanque. lleva aceite del que quieras un 20w50 estaria bien depende de que kilometraje lleve pero mejor ponle un sintentico...
7helpful
4answers
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
1helpful
3answers
Palanca de cambio de velocidades no funciona
posiblemente la barra que conecta la palanca de cambios se solto de alguna manera. Con el motor apagado, mientras se mueve suavemente la palanca de arriba a abajo, revise debajo del tablero empezando en la columna de direccion. Una vez que la barra haya sido localizada, sigala can la mano hasta encontrar donde esta desconectada o suelta. Yo tuve el mismo problema en mi camioneta ford hace un par de anos, encontre que la palanca se habia soltado de la barra, todo lo que tuve que hacer fue apretar un tornillo que estaba suelto.  Posiblemente despues de un tiempo vuelva a ocuriir el problema si no se asegura de que el tornillo este bien apretado o de que la palanca de cambios no este totalment hacia arriba en Park. Buena suerte desde Houston, Texas.
334helpful
9answers
Poner a tiempo cadenas de distribucion ford motor 4.0 mod 2002
11marzo2010- Necesito que me Hagan favor de enviar el diagrama para poner un motor de un tiempo de 4,0 Ford Explorer
4helpful
4answers
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
