Question about Electrical Supplies
Generator set starts runing for about 1 hr and then shutdown suddenly with speed fault messege dilplayed on the protection board
  • 26 Answers
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator,or its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that then it shuts down.
Posted on Jul 12, 2009
I have a Predator 4,000 generator that wont stay running. I followed all recommended instructions before trying to start it. It ran first time for about two minutes and died.same thing every time.
sounds like a fuel flow problem.Pull the fuel line off at the carb and see if fuel flows well when you turn the gas on.If the fuel is flowing to the carb,you will have to remove the float bowl off the bottom of the carb and check for fuel flow through the needle and seat which the float controls in the carb.If fuel flows well through the needle and seat and the float words well without binding, next is to clean the main jet which may be plugged.Ethanol in the fuel these days can cause problems in these areas.ALWAYS shut off the fuel in all small engines and let the carb run dry when storing small engines for any length of time.
Feb 07, 2018 | Cars & Trucks
How to fix over speed fault in desiel generator?
On the flywheel is a small sensor you should see it, like a threaded bolt with wires, that goes into the housing. This is the mag pickup speed sensor, it can get metal filings on it causing this fault. Unscrew it and wipe it off, screw it CAREFULLY all the way down with your fingers until it touches the flywheel then back out one turn, it is a small gap. Crank engine and measure the voltage on the sensor wires will be approx 2 VAC if it is working, if not replace sensor
Aug 27, 2012 | Taylor Mobile Generator Set 80 kW, 480...
Wont start
1) please LUBE THE deck bel, this happen because the lack of maintenance, the machine is shutdown for enoug friction , this mean maybe there are deck worn.This shutdown for protect the electronic system
2)LUBE the rollers bearings. too
3) test the input voltage motor, if there are the motor need repair or replace.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Jul 10, 2012 | Icon Image 17.5 S Treadmill
Frequency adjustment or solution
Can you check the RPM of the engine? 3600 RPM = 60 HZ. If it is running around that speed, try a different frequency meter.
If it was producing 180 HZ, it should automatically shut down and show a fault code!
Dec 15, 2011 | Briggs & Stratton Electrical Supplies
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Monitor dead
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Philips Computers & Internet
Monitor power light is blinking .but monitor is not displaying anything after 4 hr monitor blinking light is become slow and when restart the monitor is displaying after 4 hr please help me i have a 20.1...
If there is a flashing led on front of the monitor, that indicates a fault condition.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Oct 15, 2008 | Westinghouse LTV20V2 20 in. EDTV-Ready LCD...
50" Projection TV
your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Feb 24, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Electrical Supplies Logo
81 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
