Question about Hayward SAND FILTER, PRO SERIES
I can not get vacuum pressure on my Hayward Sand Filter. I am using the Aquabug auto vacuum(which I've used over the last three seasons). When I fill the hose and put it into the skimmer port, I lose outflow pressure and then bubbles intermittenly come out of the outflow with very reduced pressure. There seems to be air trapped somewhere?? I have opened the waste cap at the bottom and let the filter drain out water. I also; backwashed, rinsed, recirculated and waste ran the filter, but still have the same issue. Thank you!!
  • eng62rules Jul 20, 2009
    Thank you XPoolGuy. I just went out and there was a leak coming out of the strainer cover. It is definately the o-ring.
    I appreciate your time.
    Scholar:
  • 34 Answers
The filter is most likely not the issue at all.
When you lose vacuum pressure and see bubbles the problem is usually air getting into the line killing the prime. The most common place that air gets into the line is from the strainer cover on the pump. The clear lid on the front of the pump has an o-ring that after 3 years is probably due for replacement.
With a bad o-ring it's easier for the pump to draw air through the lid then water through 20+ feet of vac hose. Replace the o-ring, make sure it is lubed well with a non petrol based grease.
The only other issue that may cause this is a cracked or seriously warped strainer lid, which should be easy to recognize once it is removed to replace the o-ring.
Once this is done you should be fine.
Posted on Jul 14, 2009
My Hayward sand filter vl40t32 will not vacuum. It is only 1 season old, and I have never gotten it to vacuum. It does, filter, but not pulling the water for vacuuming...
Before you hook up the vacuum attachment, you want to flood the vacuum hose with water or your pump will be air locked. Submerge the hose and fill it with water. These centrifugal pumps must be primed in order to work. Another method is to fill the vacuum hose with water from a garden hose.
May 27, 2017 | Hayward Pool & Spa
At what pressure should you backwash a sand filter
The back pressure at which it's time to backwash a sand filter is about 6-8 psi above the baseline pressure of a clean filter. Just after following the procedure to backwash and rinse your filter, check the sand filter's back pressure at the time you return the pump and filter system back into filter mode. This is the baseline pressure of your clean filter. As the filter gathers particulates from the pool water, the back pressure will rise over time, as indicated on your pressure gauge. Once the pressure reaches 6-8 psi above the baseline, it's time to backwash.
Some advice: Don't assume the baseline pressure will remain the same for your sand filter. The baseline pressure will change over time and when the sand media is replaced. Typicallly baseline pressure will go up slightly over a season due to captured particles that are difficult to backwash out. Use of a filter cleaner will help remove these captured particles.
More advice: Even with the use of filter cleaners and proper backwashing, sand media will not last forever. The constant water flow and movement of particles in the sand over time shears the surface of each little sand grain. Like a river flowing over rocks, over time each sand grain surface is smoothed, and thus its effectiveness for capturing small particles is reduced with ongoing use. A typical rule of thumb is to replace the sand media +/- 5 years. Some pool owners do it more often, some less. It depends on how long your pool season is each year and how much debris the filter much extract from the pool water.
Jul 16, 2014 | Hayward SAND FILTER, PRO SERIES
My bug worked great last season but this year I will find it stopped in the pool not moving, I will pick it up and push on the feet to get them running again and it will stop again, what do I need to
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
  • Low water flow thru circulation system
    • Dirty Filter
    • Baskets filled with debris
    • Clogged Pump Impeller
    • Clogged suction line between suction port and actual cleaner
    • Clogged/plugged cleaning unit itself
  • Worn gear assembly within the LadyBug
Jun 12, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
How do I hook the bug to my sand filter?
You should check out figures 6, 7, and 8 in the owners manual for these pool cleaners. There are detailed pictures that show you how to connect the cleaner to the filter.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Jun 25, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
I have a swimpro sand filter it is 5 yrs old and this season when i started it up it doesn't seem to have very good pressure i have backwashed it three times and it wont even run my pool cleaner no...
If there is not much pressure, the problem is with the circulation system. Probably the pump.
When a sand bed gets old the pressure goes up on the guage, but the filter doesnt do much. When there is a lack of pressure, its due to a problem with the water flow. Usually a clogged impeller, strainer basket, or skimmer basket.
The most common solution for a loss of pressure is to dissasemble the wet end of the pump, clean out the impeller, and replace all o-rings and seals, including the shaft seal. This will revitalize the performance of your pump.
Jun 02, 2011 | Hayward SAND FILTER, PRO SERIES
Can u hookup hayward Aquabug to intex above ground pool without disconnecting existing filter? Will both filters work at the same time? I would like to clean the top of the pool at the same time I clean...
You Aquabug pool cleaner works WITH your pools filter. You much connect the cleaner to your filter system and the filters suction is what powers the cleaner. Since they operate together, you should always run your filter while you are cleaning, but it will never operate in its normal capacity since you are using it for a different purpose. Here is a copy of the users manual if you have any questions about how the cleaner works.
Jul 03, 2010 | Hayward Aquabug Above Ground Pool Cleaner...
We have a hayward sand filter for our 24ft round above ground pool. We changed the sand this season and replaced the 8 fingers @ the bottom of the filter tube. After doing so and turning the pump on it...
its more likley to be too much sand in it and its just cloged up,,,take the sand out and run the pump out of the pool in a big tub of water to flush it out and also to back flush it,,,if its working ok after that fill it up with the right type of sand but only a little at a time,,,,
i dont think the phosphates are a problem its not being filterd thats the problem this needs sorting out fast or the pool will fill up with algy and green slim
Jun 20, 2010 | Hayward SAND FILTER, PRO SERIES
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
364 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
