Question about Brother MFC-5440CN All-In-One InkJet Printer
Printer not pulling papper to print sheets - Brother MFC-5440CN All-In-One InkJet Printer
  • 3,741 Answers
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Jul 11, 2009
Load fhoto papper to printer
Well the glossy side goes down, the dull side lays up. It gets pulled in and rotated then printed on,I think that's what u are asking for?
Feb 20, 2015 | Cannon Office Equipment & Supplies
Cannot print card stock from samsung sl-m2820dw tray
your paper type is not missmaching the printer papper in sencer please try to correct fill the papper in to the papper sncer liver
Mar 07, 2014 | Samsung Office Equipment & Supplies
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
Papper got stuck . spongy peace 9"x1/2" came out ,
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
Jun 11, 2010 | Lexmark Office Equipment & Supplies
Printing papper two sida is no quality
check quality of paper,printer settings, and the toner, these are usually responsible
Mar 29, 2010 | HP LaserJet 1600 Printer
Papper locked in laser printer.
check the back of printer there is a door to remove jammed papers. open it it should flip down and you can easily remove the paper. but switch off the printer before removing paper.
Mar 25, 2009 | Brother HL-2040 Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
73 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
