Question about LG X-Note LM50 Notebook
Lap top is dead
My laptop (LGE5 Config GE50) was connected for charging and working well.
As I was going on a holiday for 5 weeks I switched off the electricity mains. When I returned the laptop appears dead as the power switch does not respond.
Please help!
  • 46 Answers
Re: Lap top is dead
Do you have tried remove the battery and plug in the power cable and try to turn on the laptop? That could be caused because of the battery.
Try it and tell us more.
Posted on Nov 15, 2007
0 characters
3 Points
Hello i have Toshiba lap top when turned on its on for 2 seconds then switches self off ,it will not switch back on even by taking battery out connecting power then.
The battery is not charging, the laptop may be in hibernation.
It should still work nevertheless. Try pressing F8 to go in to safe mode
Oct 13, 2014 | PC Laptops
MY LGE5 MODEL, GE50 Configuration can be upgraded to what possible maximum RAM
This model LG can support a max of 2Gb of RAM
You can check the specifications of this laptop from this WEB site.
Jul 21, 2011 | LG X-Note LM50 Notebook
My aspire 3000 was working fine but now won't turn on at ll....the battery light is on when adapter is connected and ive et it charge for 24 hours at least....but no life in the laptop!! is the battery...
first uplug your lap top over charging your laptop will burn the cell in the battery pack now try something turn your lap top on like you would any other now all your seing is a black screen right ok now what you is keep pushing f2 5or 6 times or intell you see first page now whats you do is change your dialog with your arrow keys on key board when you have changed it to f12 push f10 acnowledge it now the first page that comes up push f12 now its going to ask do you want to run your windows go there then push enter.
Jan 30, 2011 | Acer Aspire 3000 Notebook
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
Lap top switched off and now wont switch on,
boot from CD need the OP SYS or recovery disk that came with the computer
Jul 28, 2009 | Fujitsu AMILO PC Laptops
How can i turn on my wireless capability, my lap top is aspire 2930z
there must be a wireless switch present on either the side of the laptop or near the keyboard.
another method is:
for windows xp: start->run-> type services.msc and press enter-> find wireless zero config-> right click on it and click restart.
for windows vista type the same command in search bar in the start menu and search for wlan szero config and restart it.
Jun 30, 2009 | Acer Aspire 4520-5582 Notebook
LG X-Note LM50 Notebook Logo
166 people viewed this question
Top LG PC Laptops Experts
Are you a LG PC Laptop Expert? Answer questions, earn points and help others
