Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Problem fitting new motor into dyson dc07 casing
Is ther an easy way to fit a new dyson motor into its plastic /rubber housing?
  • 372 Answers
There is try this site
Posted on Nov 15, 2007
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
  • Do detach the black wire that goes to the motor as it does not require removal.
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
I have a dyson root cyclone. i dismantled it to replace the belt, it is not the belt which is on the roller brush, it is the belt which is from the motor, it was easy to take out as it was broken, i will...
The belt that fits on the motor is the same belt that drives the roller brush, all you need do to gain access is remove the sole plate, normally attached with 3 quarter turn connectors, use large flat screwdriver to turn them
Apr 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I fit a new duct lower motor cover?
Have a look at which has some very useful info on dismantling and repairing Dysons.
Mar 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I fit anew motor to my Dyson animal DC07
Have a look at .
You'll need good DIY skills and a Torx driver.
New motors are avaible on eBay for about £20.
Feb 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i fit new brushes in dyson dc 07 have the
you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 motor overheats
the motor brushes are worn down and can be expensive to get someone to fit them for you so i think its time for a new cleaner
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Brush bar on my dyson dc07 will not turn.
Your Dc07 may have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help
If you dont have the clutch arangement then just turn the three plastic screws on the sole plate ( Under front of machine) to unlock pull off sole plate & fit new belt to brush roller.
Easy job to do.
Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07
Depending on wether your machine has A clutch fitted will decide how easy this job will be.
The non clutched model is very simple turn the 3 plastic screws on sole plate to unlock position lift plate off remove belt from motor shaft & lift out brush roller.
Replace belt & roller fit sole plate & its done.
The clutched version will require the removing of the sole pate,
Then remove brush roller. & brush roller housing.
Then remove clutch cover,
Replace both belts & reassemble.
Its A lot to explain in great detail so try this site if your struggling.
Jun 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc07 motor sparks
I think you are looking at replacing the motor with a new one.
Dec 30, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
380 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
