Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Session 3 initialization failed - Dell Dimension 9150 (DIM915MIN) PC Desktop
  • Douglessd
    Douglessd May 11, 2010
    You have not given us much to go on here :) I assume you are getting this message on a blue screen when you boot your PC. If so it can be a very complex problem. If this problem occurred with out you changing anything on your system then you probably have a hardware failure. If you are trying to reinstall or upgrade your system then you probably have a driver problem. You may need to download a new driver from your hardware manufactures web site.
Ok, after countless hours searching and sleuthing for this issue, I could not find a resolution...until now. This is my first post ever on a technical forum, so be gentle to me. I will probably never reference this form, so you if this helped you, please let me know by sending me comments to my email at: cancermage@hotmail.com
Technical Symptoms: Blue Screen (BSOD) Session 3 Initialization Failed (Session3_Initialization_Failed) STOP 0x0000006F (0xc0000034) This BSOD would load for both normal and safe mode. The operating system in question was Windows XP Home SP2.
Reason: The issue occurred after I ran a virus scan using a PE boot disk that deleted the C:\windows\system32\smss.exe system file.
Resolution: By using the "dir smss*.* /s" at a DOS prompt from the PE boot disk, I was able to search the whole computer for any available files and it found a clean version in a directory. So to fix the issue I copied C:\windows\$ServicepackUninstall$\smss.exe to C:\windows\system32\ using a PE boot disk.
Acknowledgements: http://support.microsoft.com/kb/153742 , this link gave me a hint that it may be smss.exe (even though it references win2000). Upon looking at the antivirus logs, sure enough the smss.exe was found to be infected and deleted it as it could not disinfect it. I'm assuming if I did not have a virus free smss.exe file on the C: drive in another folder, I may have to pull it from a CD or find it online.
Sincerely,
John White A+,MCP,CCENT,CCNA,MCITP cancermage@hotmail.com
Posted on May 19, 2010
  • RLCODTech Sep 22, 2010
    Cancermage,
    Thanks for this posting. I had a continuous boot loop after running some antivirus tools and after finally getting the error code and searching for a fix I ran across your response. I used my UCBD disk and was able to search and find the file I needed. The only difference was the file copied was c:\windows\NT$ServicepackUninstall$\smss.exe. I recommend than everyone use the dir smss*.* /s command at the dos prompt to get the exact file name needed to copy.
    Thanks again because without your post I was stuck.
    Scholar:
  • 56 Answers
This is more often than not a driver issue.
Hit F4 as the computer is booting up and boot it to the utility partition to run the dell diagnostics. If no hardware failures are detected it may be a piece of recently installed hardware with a bad driver.
Boot the computer into safe mode and uninstall and remove all newly installed hardware and deleting them from the device manager.
If that doesnt fix your problem, it could be a boot sector related virus. Boot the computer back into safe mode and run a virus scan by going to housecall.trendmicro.com. If none are detected the easiest thing to do will be to restore the computer to factory settings.
Make sure to back up all data files to a cd or external storage medium and make sure to scan them again for viruses before loading them back onto your computer.
You can restore the computer back to the orignal factory settings by hitting ctrl+F11 while starting up. NOTE!! Restoring will cause a loss of all data on the computer and return it to the condition when you first got the computer.
Have fun and remember to scan your backups for viruses after backing up your files. And make sure to do it in safe mode.
Posted on Jul 12, 2009
Why Does the TCP Connection Fail Even If the Server and Client Both Initiate a TCP Connection?
LDP sessions are established based on TCP connections using MD5 authentication. The TCP connection cannot be established, if one end is configured with MD5 authentication while the other end is not, or the MD5 passwords on the two ends are different. If MD5 cipher text authentication is proprietary on other vendors' devices, Huawei devices cannot set up a TCP connection with these devices.
TN11D4001 Huawei TN11D4001 Board Thunder link com
Oct 08, 2016 | Computers & Internet
Charge time
Around 2 hours for initial charge. I've had 30 minute charges recently on a used system. I would consider a charging station that is in a handy location so then you can keep it constantly charging and still easily accessable when you are ready to begin your blood sessions.
Jun 09, 2014 | Sony Playstation 3 (PS3) Console
Did not receive an answer from Suhail
Hi Rick,
I am sorry about the lost chat session. I am not sure what happened but the Chat session ended. Could you re-initiate it again or mention to me the printer problem you are facing here ?
Regards,
Suhail
Oct 17, 2011 | Office Equipment & Supplies
The free hidden and dangerous (1) gives errormessage: 'failed to host session' and 'failed to initialize network connection' when trying to start a coop LAN-game. When trying to start a coop LAN-game in...
Since windows 7 you cant Host a game anymore! The only chance to host and play Hidden & Dangerous Deluxe under Windows 7 is to install VMWare Player and then install WinXP on it (VERY EASY AND FAST, you need a WinXP CD or a ISO file). Then you have to activate Direct3D under the settings of VMWare and it installs automatically VMWare Tools. After this you can install H&D Deluxe on the VM and play the game in full resolution and full speed (fps) without any error!
This helps if you have problems with hosting a game under Win7 with these errors:
Hosten einer Sitzung fehlgeschlagen
Dec 28, 2010 | Take 2 Interactive Hidden & Dangerous 2...
After turning it on, after a few seconds it turns green and then shuts off. How do I fix this problem?
I'm sorry, I lost chat contact with you.
Please re-initiate chat session to finish the tv chat session
Jul 27, 2010 | Televison & Video
I have to much sessions allocs fail. The sessions bar is always on red color
You sem to be maxing out the session table on your
Firewall.
If you have a SSG5, then your max session limit is 8K
To find out what your max session is type: get session info
In the below output, the max session limit is 8064
-Greg
gateway-ssg-> get session info
alloc 49/max 8064, alloc failed 0, mcast alloc 0, di alloc failed 0
total reserved 0, free sessions in shared pool 8015
Oct 06, 2009 | Juniper Networks (SSG-5-SH-BT) Firewall
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
12,735 people viewed this question
Clive
Clive
Alun Cox
