Question about RCA HD52W59 HDTV Projection Television
I have a rca 50 hdtv projection tv that turns itself off then on and has 3 colored lines that goes across the screen when it turns back on
  • RCA Master
  • 8,617 Answers
Vertical output failure causes the three lines across the screen
Posted on Jul 12, 2009
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
I have an RCA Scenium 61" DLP tv. Recently when you attempt to turn it on, it turns back off and the power button blinks three times. Then the tv will continuously attempt to turn itself back on with the...
sounds like you need to replace the color wheel but most of the time that is almost as expensive as the TV itself best bet for this problem would be to bring it to a shop and have it serviced
Mar 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
250 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
